Old 02-24-2008, 01:27 AM   #1 (permalink)
McLoving
B13 throwout bearing maybe???
Hey guys im new to the forum and got a couple questions about b13's. Tommorow im about to purchase a se-r for $1000. There are a couple of problems the biggest one is that it wont go in gear. the owner said that its the throw out bearing. If thats the case then I guess ill have to buy a brand new clutch kit and have it installed as thats what i was told. Am I right or is there another option? then the driver side door wont open i assume thats a easy fix. i already own a b14 se with a sr20de with other problems of its own(it runs and can be used whenever i like but i dont drive it). But i want to make the b13 my daily driver. if the throwout bearing is the problem will i be able to move the car without a tow truck tommorow or is the tow truck my only option??? thanks alot in advance to anyone who replies!!
vangaurdbiz is offline   Reply With Quote
Old 02-24-2008, 07:33 AM   #2 (permalink)
Even with a bad throw out bearing, the car should go into gear and move through the gears when the engine is not running. If it won't do this (it may bind between a couple gears or not go in reverse, but it should be able to go into some gear(s)) then you may have a bad tranny.
If the car will shift with the engine off but will not go into gear when it is running, it could be the throw out bearing or a screwed up clutch, either of which would suggest that you need to get a clutch job done. With a bad T/O bearing, you will usually hear a noise when you depress the clutch.
Or it could just be that there is too much play in the clutch cable. If this is the case, you won't hearing the bearing grind or squeal, it will just grind when you try to put it in gear with the enging running. I would definitely check the clutch cable adjustment (sometimes they stretch and get too much play). If there is too much play, you should be able to shorter the cable so that the clutch disengages.
The hinges often fail on the drivers side door. This could be your problem, and, if so, it's an easy fix.
As to whether you can move the car, it won't be easy if it will not go into gear.
Old 02-24-2008, 10:40 AM   #3 (permalink)
McLoving
thanks alot Bill!!! Im still waiting on the guy to call me so i can go pick it up....the car needs some paint but the interior is spotless. Except for the fact that it has no panels in the back, and ther is no headliner!!
Old 02-24-2008, 09:14 PM   #4 (permalink)
Good luck with your new ride.
