Old 02-24-2008, 12:20 PM   #1 (permalink)
Drive Like Gas Is Cheap
cluster help
ok i did a 93 sr20 swap into a 93 ga16 every thing start up fine and most lighting works but all the dash lights.also the cluster is not working either,so here is what i check so far on the car
fuese
ecu
harness
cluster
if any aboy can help that would be great really need this car to run asap. here is sone pic of some left over plugs that i think might be the issue why the car is doing this
the ga16
the sr20
sr20
ga16
B13 Sentra SE-R.
92 Black13 is offline   Reply With Quote
Old 02-24-2008, 09:51 PM   #2 (permalink)
is everybody in this forum this useless
Old 02-25-2008, 02:18 AM   #3 (permalink)
SE-ARRRRRGGGGHHHHHHH!!!!!
Oh yeah, you're really going to get someone willing to help you now. Tool.
nobbie is offline   Reply With Quote
Old 02-25-2008, 04:59 AM   #4 (permalink)
B13 GTi-R
Your cluster is not working because JDM motors are 14.2 volts and your USDM motor was 12 volts. Increase voltage and it should work.
92 Nissan Sentra/GTi-R
-->12.9 @ 111 @ 13psi<--
88 300ZX Turbo (The Drift Project) (SOLD, so sad.)
"Life's Hard, It's Harder If Your Stupid."
Gettinzidewayz is offline   Reply With Quote
Old 02-25-2008, 08:08 PM   #5 (permalink)
pic is up
Old 02-25-2008, 10:22 PM   #6 (permalink)
808 SE-R Mafia: KUKI-MSTR
are you always this impatient? j/k
i know how you feel, but this is a forum, not instant messenger.
i know if i post a topic or question, i'm refreshing my browser every 5 seconds because i'm anxious to get an answer, but essentially you're asking the whole car-driving-sr20-loving world. it might take a while given time zones, i'm usually on at night here in Hawaii and i've learned not to expect an answer til at least late afternoon the next day. Nearly everyone else is at least 2 hours ahead of me (sleeping when i post) and can't respond until they get off work (unless they post at work like me ) which would be later in the day for me.
Otherwise, props to you on the swap, maybe one day i'll have the courage, time and commitment to do one. (hopefully not out of necessity )
Chuck Norris once raced a VE. After winning he was so dissapointed he roundhouse kicked the VVL badge into a VTEC badge and called it a honda.
Since then Chuck only rolls turbo.
I have neither...but it still makes me smile
lazyieg is offline   Reply With Quote
