Old 03-24-2008, 09:26 AM   #1 (permalink)
SKITZO_SER
tempeture gauge problem
i noticed it started today it seems that when i give my sentra some throttle the water tempeture gauge goes down as the rpms rise has anybody had this problem if so any info how to fix it would be greatly appreciated
SKITZO_SER is offline   Reply With Quote
Old 03-24-2008, 10:08 AM   #2 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
Check your grounds, especially the one from the battery to the chassis thrn to the thermostat housing.
Old 03-26-2008, 09:44 AM   #3 (permalink)
Nismo_34
Project All High School!!
Mine does this as well. Even when I'm just revving the engine. All of my lights in the dash pulse as well.
White 91 SE-RR
My Car My Space
Nismo_34 is offline   Reply With Quote
Old 03-26-2008, 10:21 AM   #4 (permalink)
chriscar
chriscar's Avatar
Sounds like ground problems to me.
Old 03-26-2008, 03:50 PM   #5 (permalink)
classicaddict
this foreum= FAIL
wow.....................there is another thread identical to this and it was made 2 days ago. way to go champion
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 03-27-2008, 05:37 AM   #6 (permalink)
billc
This is a common problem. It is caused by vibration at the water temp guage sending unit. Over time, the contact between the connector and the sending unit itself breaks down and engine vibration interrupts the signal to the guage. Replace your guage sending unit and this will probably fix the issue. If you search around you will be able to find the location of the part and instructions on how to do this.
