ive been driving my car with my stereo blasting for a while now. and i was just driving like a normal day and my car battery light was on and i got this ticking sound coming from my dash. i check my charging system voltage and i was at 12.5 so i changed my alt. then started it again and the same symptoms occured. so i replace the battery. same thing happens. check my system voltage and at 13.8 normal for my car. the ticking is coming from behind the fuse box under the dash. its a block with a whole bunce of wires and it looks like a relay or some sort thats making this clicking. top left of the block of wires. it only happens now when im below at 700 rpm. when im above it everything seems fine but the batt light is still slightly on. (dim) but still there.
is there anybody out there that has had this happen to them? anybody know where i can get a wiring schematic for this?
