Old 08-12-2008, 09:26 PM   #1 (permalink)
93 broke down need help
ok I own a 93 sentra gxe auto its my daily driver I bought it about 2 weeks ago my car wouldnt turn on so I tried jumping it the starter wont even turn I tested my battery its good can it be my ignition switch or starter..as soon I get my car home Im testing the starter ...ohh I tried looking for the starter last night couldnt see it it was to dark out side and tonight Im going back and taking it off who knows bolt size messure ments and were is the starter since im working in the dark........thanks
lmn8 is offline   Reply With Quote
Old 08-12-2008, 10:34 PM   #2 (permalink)
SE-R Abuser
im not very familiar with the ga's but i believe its on the back of the engine under the intake manifold.. i think the bolt sizes are 14mm not sure on that.. also i reccomend a flash light :p
91 se-r engine swapped in from the 92
92 se-r wrecked an scrapped
92 e/xe or whatever 1.6 auto (gf's whip now)
77 datsun 620
lynchfourtwenty is offline   Reply With Quote
Old 08-13-2008, 05:17 PM   #3 (permalink)
i WOULD CHECK THOSE CABLE FIRST...I HAD SIMILAR SITUATION AND RIGHTAFTER I REPLACED THE DAM STARTER ;IT TURNOUT TO BE THE POSITY CABLE NOT TIGHT ENOUGH.
timbales is offline   Reply With Quote
Old 08-15-2008, 03:42 AM   #4 (permalink)
sr20 powerd
the starter is super easy to replace on the ga its right below the throttle body
just remove the whole intake and its right there two 14mm bolts and a 12mm nut and its out
nissan motorsports = nismo
honda motorsports= homo
1992 se-r down for now
1992 ga16 getting ready for an sr
kyledriver is offline   Reply With Quote
Old 08-15-2008, 07:28 PM   #5 (permalink)
I replaced the starter except I didnt feel like messing with the intake manifold so I jacked up the car and went to work removing the bracket that the ZI/M rest in and then with the starter...damn I had the hardest time removing it then i noticed that the other bolt was ontop on the other side with the ground wire....thanks for the responses....
