just did a swap and had fuel problems.(b13 also)
first probe it see if it get power at the wires at the back fuel pump the 2 plug that has 2 wires black/red.if u get no power run a power line straight.second u can take off the fuel send line by the pump put key in on ignition and see if i starts to squirt gas. if not you take out fuel pump and see if the little filter is still on if not that will cause no fuel delivery.. through out this you should be able to hear if the fuel pump is working or not.
