Old 09-16-2008, 07:54 PM   #1 (permalink)
ve or det?
need help with nx 1600 cluster
how do i hook this up to my b13...two of the plugs, plugs and play, but there's one that dosent fit...do i just wired it to the harness or just let it hang there...thanks...
se-r_311 is offline   Reply With Quote
Old 09-16-2008, 09:18 PM   #2 (permalink)
sr20det inquirer
search is your frien d this has been covered several times but since im nice here you go:
http://www.sr20forum.com/technical-i...4-se-r-nx.html
Do not go where the path may lead, go instead where there is no path and leave a trail.
92_sEnAtRa is offline   Reply With Quote
Old 09-16-2008, 11:03 PM   #3 (permalink)
ve or det?
opps my bad...thanks..
Old 09-16-2008, 11:43 PM   #4 (permalink)
4dr SE-R
I did this swap on my XE 4 door. I promise you that there is nothing plug and play about that cluster. the plugs may fit but the wires are different. I tried just pluging mine in too at first, but when I turned the key forward to check if it worked the cluster started smoking. so I had to rewire the plugs for it to work in my car. all in all it took me about 12-14 hours between two days to get it right, and Im good with electronics and wiring.
SR20s rule is offline   Reply With Quote
Old 09-17-2008, 12:28 AM   #5 (permalink)
i want to do this too, but i'm a real big newbie, where is the "speed pinion" located at in the nx1600...please help me out too...thanks..
sr20b13 is offline   Reply With Quote
Old 09-17-2008, 11:33 AM   #6 (permalink)
~Run what you Brung~
Trader Rating: 16 (100%)
the speed pinion is located on the tranny.
you should really go by the wiring diagram they have here. i installed two of these already and you can fit a plug but they wiring pins are not the same.
THE WHIP:
91' SE-R on 15's, they look like 20's though
DAMN, my car is slow [/color]
shingouki1 is offline   Reply With Quote
