Old 09-29-2008, 03:29 PM   #1 (permalink)
whats up. put together a 93 xe need a lil info
its a 2000 g20 block the ?. it came with the axle bracket on it but the axle dosent meet flush to screw the three screws in(has about a 3/4 inch space). do i need a nissan ser bracket for it so it can be flush or will the g20 axle bracket work for it?
classic93sr is offline   Reply With Quote
Old 10-01-2008, 05:08 AM   #2 (permalink)
SE-R Abuser
did you try tightening the bolts? i tightend mine a little at a time an moved on to the next an kept doin that until it pulled the axle inward an everything was flush.. if the bolts are acting like they dont want to go in somethings wrong, also im assuming your using b13 se-r axles right?
91 se-r engine swapped in from the 92
92 se-r wrecked an scrapped
92 e/xe or whatever 1.6 auto (gf's whip now)
77 datsun 620
lynchfourtwenty is offline   Reply With Quote
