Old 10-05-2008, 09:44 PM   #1 (permalink)
Digital Cluster Help
Ive read the diy cluster and ive herd different things about them. ive herd its pnp. ive herd everything has to be rewired. ive herd all you need is the cluster and the speed sensor. ive herd all you need is the cluster. btw between the b13 years did some come cable speedo and electronic speedo?
JayGThatsMe is offline   Reply With Quote
Old 10-06-2008, 09:41 PM   #2 (permalink)
you may not wanna hear this, but someone told me that the ECU has to match the digital cluster.
Of course I argued. I believe all the sensors are the same, the wiring diagrams for the different cars are the same, I believe you will have no problems swapping in the cluster in... But I never had one out before.. A friend has one, I'll ask him if I can pull it and compare. I gotta junk cluster layin out..
I saw a Lambo once, it was in my rear view getting smaller.. go figure
det-ser92 is offline   Reply With Quote
Old 10-06-2008, 10:02 PM   #3 (permalink)
b11vet 1320
I just installed one in my94 b13 ...everything works perfect on it and looks great...if you need a diagram or help or even pics to see what it looks like at night let me know...and yes u need the electric speed sensor to make it work(found in the 94 b13)let me know
b11 racer
yader is offline   Reply With Quote
Old 10-06-2008, 10:07 PM   #4 (permalink)
4dr SE-R
1.91-92 B13 use a cable speed sensor
2.93-94 B13s use electronic
3.it doesnt matter what ECU you have. people have put these clusters into B14s with no problems
4.make sure that you get the right speed sensor. the speed sensor has to match the motor/trans combo that you have. so if your car is a 1.6 manual then youll need a electronic speed sensor from a NX1600 manual, if your car is a 2.0 manual then youll need an electronic speed sensor from an NX2000 manual. there like 40 bucks at autozone
5.on the back of the clusters it says where almost every wire goes. the plugs for the indicator lights are the easiest to change over. but there is a black plug in the middle of the NX cluster. this plug controls the gauges and tach. your going to need a wiring diagram for this plug because it doesnt say where any of the wires go.
6. on a scale of 1-10 this swap is 7 on the difficulty scale
SR20s rule is offline   Reply With Quote
Old 10-07-2008, 01:17 AM   #5 (permalink)
wow thanks lol that explained everything. ma i could get one at the junk yard too but i just dont want to deal with the wiring. its too cold out lol
Old 10-07-2008, 01:34 AM   #6 (permalink)
4dr SE-R
hey what do you drive??? im always around waukegan.
Old 10-07-2008, 01:39 AM   #7 (permalink)
ya i drive lol. what do you drive?
Old 10-07-2008, 01:46 AM   #8 (permalink)
4dr SE-R
i was talking about what car do you drive.
heres mine
i have different wheels now though
Old 10-07-2008, 02:47 AM   #9 (permalink)
Trader Rating: 15 (94%)
hm i wonder how this would look in my p10
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 10-07-2008, 04:23 AM   #10 (permalink)
I'm looking for a ve head
Ok so what if I have a 91 b13 with the cable speedo and I want to use a 93 cluster with the electric speed sensor? Is that electric speed sensor plug on the 91/92 wire harness and just not used? Also, will the 93 cluster plug right into the 91 cluster harnesses and all I need to do is run a a direct plug for the electric speedo sensor?
For sale items......
Jdm 4-fog bumper-SOLD
Jdm intake mani-$50
b14 side skirts(custome for b13)-$100
93/94 guage cluster
speed sensor also
Mr. Sleeper is offline   Reply With Quote
Old 10-07-2008, 10:56 AM   #11 (permalink)
4dr SE-R
it wont be plug and play because the wires are different, so you will have to rewire it, as for the speed sensor, if your car didnt come with an electronic speed sensor then the wires wont be there, my car is a 92 so I had to convert it to electronic, I did this with no wiring diagram so I just made my own harness for it. its only two wires. so I ran the wires from the sensor through the firewall to the right wires on the cluster
Old 10-07-2008, 10:22 PM   #12 (permalink)
heres mine
lol no sh*t duh me. i drive a 94 sentra xe stick. green about to be flat black. dude i saw you today at pick n pull i was drivin my corvette lol. umm. what did you do with the other rims. im looking for some rims for my sentra. its funny cause the sentra was suppose to be my winter beater and im fixing her up lol. im a honda guy but im loosing interest in them. their over rated. but anyways if im too lazy to do the nx cluster swap can i just take a cluster with rpm and pnp it? i found a stock white gauge off a 200sx fits but pnp?
Old 10-07-2008, 10:32 PM   #13 (permalink)
slammed on stock spring
Old 10-08-2008, 04:29 AM   #14 (permalink)
any one has a pic of the back of this cluster? adn teh front to see the shape in comparison to my p10,
Old 10-08-2008, 11:12 PM   #15 (permalink)
4dr SE-R
yep I was picking up some radiator fans and an alternator for my SR20 swap,
Old 10-09-2008, 01:20 AM   #16 (permalink)
let me knoe how that goes i might do it. do you have an engine? pnp got a couple
Old 10-09-2008, 01:59 AM   #17 (permalink)
4dr SE-R
yeah. I got a lowport SR20 out of a 97 200SX it only cost me $100 at PNP
Old 10-09-2008, 02:27 AM   #18 (permalink)
~Run what you Brung~
Trader Rating: 16 (100%)
you cannot use a 93 digital cluster in a 91-92 car. the wiring isnt correct and to make it work you would need a fsm for both cars to match to what goes connected there.
it doesnt matter what speed sensor you use as long as its electronic. you can use a B14 speedo sensor, you can use a nx1600 speedo sensor.
some people say that if you get the digital cluster from an automatic car you need the automatic speed sensor from that car to match the cluster. i havent tried that since i have only used clusters that came from a stick and speed sensors that come from a stick.
so, if you got a 91-92 se-r/b13 you need a digital cluster from a 91-92 nx1600 and a electronic speedo sensor from any manual b13/b14.
(i know, i have used a b13 se-r speedo sensor, 1.6 nx1600 sensor and a b14 sensor and they are all correct and work just fine.)
if you have a 93-94 se-r/b13 you need a digital cluster from a 93 nx1600.
THE WHIP:
91' SE-R on 15's, they look like 20's though
DAMN, my car is slow [/color]
shingouki1 is offline   Reply With Quote
