Old 10-10-2008, 11:42 PM   #1 (permalink)
Sunny corner/headlight question?
I just bought the sunny corners from japan and when i went to go put them on the bracket was not the same and the angle on the head light and corner didnt match up. so i was wondering if anyone knew where to get the sunny head lights (glass) or knew how to make these fit with the 92 oem sentra lights?
se-rajr is offline   Reply With Quote
Old 10-11-2008, 12:51 PM   #2 (permalink)
~Run what you Brung~
Trader Rating: 16 (100%)
if the corner lights didnt work on your 92 se-r then you got corner lights from a 93-94 sunny super saloon. that means you cant use those corner lights unless you get 93-94 plastic headlights along with the 93-94 grill.
91-92 sunny corners are the same angle and fit as the USDM sentra corners.
THE WHIP:
91' SE-R on 15's, they look like 20's though
DAMN, my car is slow [/color]
shingouki1 is offline   Reply With Quote
Old 10-11-2008, 01:25 PM   #3 (permalink)
Ah I see, thanks. Soooo anyone have the 92 sunny corners ?
Old 10-11-2008, 10:24 PM   #4 (permalink)
GA13's Rock!
I just sent you a pm about the corners - i reposting the info here as well
i think the corner lamps you got are for the JDM B13Plastic headlamps. Philippine Spec 1992 through 1999 B13 which should also fit the U.S spec 93-94 B13
and in order to get the proper fitment for your JDM corners that you ordered, you will need the U.S Spec Plastic headlamps for the proper lighting beam, Grill and undergarnish. try fitting the jdm corners on someone's 93-94 classic to verify this.
The challenge with the JDM glass lamps (this comes from the JDM 1991 B13 SuperSaloon) is the angle of the lighting, even with adjustment we can not quite get the right angle lighting. (we are also Left hand drive here in the Philippines).
let me know if the corners fit the U.S Spec 93-94.
there is a number tag on the JDM corners that will identify if its for the glass or plastic headlamps - let me do some research - i have the 91 SKD superSaloon with glass and it has the wrong cornerlamps.
91-92 U.S Spec = 91 JDM and 91 PHDM
93-94 U.S Spec = 92 Up JDM and 91-98 PHDM
Tevs
Tevs
We LOVE JDM Junk!!!
For Sale Items
http://pinecitygarage.multiply.com/
Sunny is offline   Reply With Quote
Old 10-13-2008, 08:29 AM   #5 (permalink)
Thanks Tevs your a big help
now all i have to do is find the right corners!
Old 11-02-2008, 08:16 AM   #6 (permalink)
GA13's Rock!
Update:
if you look at the ICHIKOH corner lamps sides, you will see small numbers:
for 91-92 with Glass Headlamps - JDM corners should have the numbers 3311
for 93-94 with Plastic Headlamps - JDM corners should have the numbers 3339
Tevs
