sluggish performance - SR20 Forum
Old 02-20-2010, 08:59 PM   #1 (permalink)
Feedback Score: 3 reviews
hey. i just bought a 1991 nissan sentra se-r for 600 the car was sitting down for yr supposely. I just got the car home from the shop because the clutch was gone. i never driven a b13 se-r before so bare with me i was test driving n revving it today, on idle the car revs forcefully to 5-6rpms (not freely) when i drive it has the pick up feel to it n then the acceleration gets sluggish. so i guess to sums things up it has a sluggish performence. i'm thinking it could b that it needs a adjustment in timing with a new timing chain.
falcon021084 is offline   Reply With Quote
Old 02-20-2010, 11:43 PM   #2 (permalink)
Feedback Score: 5 reviews
b13 se-r's are not rocket ships
If it's been sitting for a year the fuel is no good and it would need drive time.
Give it a little time, look at the problems, don't just think about them, run a compression test, and have fun.
You made out if you don't spend another dime on it. You could easily part that thing out for more than 600 dollars.
Old 02-21-2010, 12:28 AM   #3 (permalink)
oh no dude, my mind set is not as that fast, my other car is a 86 mr2 n does 0-60 in 8.9 sometimes 10s flat n thats fast as sh*t for me. but i knw se-rs are fast then my mr2. but this is one slow, it feels like it has more hp then my mr2 but it sluggish, not sluggish like i mean slow, like slow like there's something wrong with the engine, feels like loss of power somewhere in there, also my car is having the knocking sound. but seriously it should hit the limiter on idle atleast i shouldn't have to compare it to my mr2 :L
Old 02-21-2010, 12:31 AM   #4 (permalink)
but ok man, i already bought the timing chain kit n will drive the se-r more for a bit. then i'll get it timed right later on. is there any suggestion that might be the culprit as why the car revs slowly?
Old 02-21-2010, 12:47 AM   #5 (permalink)
se-r FIEND
its probally your fuel. did you fill up your tank yet? how long has it had the "sluggish" feeling? you should try process of elimination before you put money into it.
all motor se-R is offline   Reply With Quote
Old 02-21-2010, 01:42 AM   #6 (permalink)
well i just filled the tank half way but i bought the car like this, i haven't really driven it that much, when me n my friend when to see the car before i bought it they turn it on my friend rev it n said the engine's needs timing done, n prob need new lifters. because there's a loud tapping sound while engine running. so i guess what he said was true. :L it really wierd. i know if u go turn ur se-r on after its warm up n rev it all the way to the limiter it will hit 7500 rpms fast right? but my car takes 4 seconds to get up there n the engine sounds really loud getting there. like it's a fat kid going up the stairs
Old 02-21-2010, 03:42 AM   #7 (permalink)
this is my car. it revs no further then 6,800 rpms :L see what i'm talking about. i'm flooring the gas pedal all the way to the floor
Old 02-22-2010, 07:06 AM   #8 (permalink)
Feedback Score: 17 reviews
It's hard to say what the problem might be. Start with the simple things. Change your oil, fuel filter, and plugs. Check the ignition timing - from the position of the distributor in the video it looks like it might be misadjusted. Check to make sure that your throttle cable is properly adjusted (so the throttle is actually open when you floor the gas pedal). Could also be a clogged cat. Also check the air filter for a mouse nest or heavy clogging. Find a used MAF and swap it out to see if that helps.
It's almost certainly not the timing chain, they almost never go bad. But if someone has messed with the cams, they could be mis-timed. If the exhaust cam is off a tooth, then the ignition timing will be way off as well and the car will run like crap.
Old 02-22-2010, 02:51 PM   #9 (permalink)
I already did oil changed n spark plugs n wires, i haven't done distributor, fuel filter or intake filter. i will take the cat out n check the distributor position n i'll check on the gas cable, i'll post another video on Saturday with these things installed. thanks i do have another spare b13 se-r maf sensor laying about in my room.
Old 03-19-2010, 04:43 PM   #10 (permalink)
Original Owner
Mine just started doing the exact same thing. I checked plugs, wires, has a new fuel filter anyway.
You can not tell anything on the distributor, because the cover is on, they all look exactly like that until you pull the cover and distributor cap by the way. My rotor has a crack and I will replace the cap and rotor to make sure that is not the problem.
I also checked the fuel injectors to make sure they are all clicking and they seem to be.
I also know that my mis-fire is only on the #1 cylinder, I can pull the plug wires from the spark plugs and #4/#3/#2 all have it run on 2 cylinders, pull #1 and no change.
After the rotor and cap, my next check will be either the EGR or pull and replace the #1 fuel injector.
Any other thoughts?
92 Red SER - Ceramic brake pads, KYG shocks, Poly Bushings and engine mounts, K&N Filter, Autometer Oil Temp/Pressure and Volt gauges
92 redser is offline   Reply With Quote
Old 03-19-2010, 08:37 PM   #11 (permalink)
SR20VE30DEwat?
Any other thoughts?
Check the plug wires where they're connected to the spark plugs to see if one of the ignition wire-boots has a crack the spark is escaping from and arcing. It helps to do it at night.
Another thought, you can test the continuity on the fuel injectors by measuring resistance with a multimeter. I believe most injectors are supposed to have between 10-14Ω.
pearl93ve is offline   Reply With Quote
Old 03-20-2010, 01:25 AM   #12 (permalink)
I just read this thread and bet the o.p.just needed to do a good tune up. I loved the you tube vid of him doing a walk by,opening the hood,getting in,letting idle and then give it he11. I wonder what ever happened?
92 ser,Avenir sr20det..Im new to this game
Garrard8 is offline   Reply With Quote
Old 03-21-2010, 08:44 AM   #13 (permalink)
Original Owner
My end result was a combination of two issues:
- #1 fuel injector with 2 fingers broken off, so the spray pattern was off, replaced fiel injector - still a slight misfire.
- a small crack in the rotor and corrosion on the cap annodes, replace rotor and cap, run perfectly.
So fuel was slightly off and the spark was not solid, but there, now solid fuel and spark and mystery solved.
Hope it helps for anyone else.
Old 03-23-2010, 10:09 PM   #14 (permalink)
Gotta love that SR20!
Seems like it starts and idles fine. If it was sitting for a year I'd suspect bad fuel and/or a family of small woodland creatures living in the intake.
SE-RMonkey is offline   Reply With Quote
Old 03-23-2010, 10:33 PM   #15 (permalink)
SE-R Joe
Feedback Score: 14 reviews
1st of all check the oil. an as always pull the plugs an c *** they look like. an of course check the timming it should be @ 15deg. how many miles on it? it probably dont need lifters. an for it to take about 4secs to hit 7500rpm is close but its not 4secs but it feels like it. an for the loud tapping if your low on oil it will sound like the timming chain is hitting the wall of the head an make that kinda noise, or its a bearing. good luck
joe92ser is offline   Reply With Quote
Old 03-23-2010, 10:40 PM   #16 (permalink)
SE-R= S-tayE-atin-R-icers
dam that engine sounds like shyt.. make sure ur valves are working, fix ur exhaust leak also.. clean ur injectors and use v-power fuel it wrks wonders!!
1991 classic b13 se-r
1989 nissan maxima
1991 honda accord h22a
1994 integra h22a
2000 hyundai accent 2.0 tibby swap
JdmGismo is offline   Reply With Quote
Old 03-24-2010, 12:42 AM   #17 (permalink)
The Autozone steering wheel cover is clearly the problem here, folks.
Are all of your injectors and plugs firing? It sounds like one of the cylinders isn't getting gas or spark (ticky/clattery). You should also clean the MAFS -- especially if the car has been sitting for a while...
GLWT.
Todd
91 Sentra SE-R
http://www.whistlehog.com/blog
sciamop is offline   Reply With Quote
Old 03-24-2010, 01:14 AM   #18 (permalink)
SR20DEviant
Feedback Score: 30 reviews
make sure to replace the cap & rotor, fuel filter, PCV valve, and get an air filter. it's probably clogged with animal fur or nuts, or anything that can make it's way in the intake tract.
Originally Posted by Serban View Post
'92 NX2000VE - SR16's, BC S&R's, Hot Shot intake w/ pop, SSAC header, 2000 SE disc, ACT HD PP, TWM shifter, FSTB & RSTB, AGX's for now, CSK's+RM's on the way, Prothane MM
'91 SE-R For Sale: http://www.sr20forum.com/cars-sale/2...ots-parts.html
PhorB13 is offline   Reply With Quote
Old 04-13-2010, 03:44 AM   #19 (permalink)
lmao @ the comments.. i should've came back for this thread, umm me and my mechanic open the engine up. we almost threw up when we saw that infestation of devilish hell inside it. engine oil had turn into mud. yeah disgusting. but it actually turns out that the sr20's timing was off, that n the autozone steering wheel cover hahahaah, lol really? anyway so i decide to go JDM swap n this is the result didn't beat'em i sure as hell kept next to him that vtaak sammnavitch
from a roll
the only problem i have now is bald tires, i spin 1st and 2nd bad :L
the rpms don't stop at 6,700 no more 8,300 rpms now baby hahaha, i think thats just a defect ***
@sr20: u like it when i press down the gas on u hmm huh? u dirty b!tch
