U need to 1st wash off any grease U might have, then take a RUBBER mallet and hit the end of the shaft- where all the balls are, and it should come right off. Its a Rzeppa type of joint, done MANNNY of these before, then U need to clean up the balls and all, slip the boot on, put all the grease in the boot, slide the end U took off back on the shaft and put the clips on, thats it.
Mike
Nissan Tech-used to be...
