Old 08-29-2000, 03:56 AM   #1 (permalink)
91ser_driver
Window fix?
Hello, I just bought a 91 se-r about a month ago and I love the car! The only problem so far is that the windows are really, really hard to roll up. I was wondering if anyone had any suggestions of how I would go about fixing this. Thanks!
Old 08-29-2000, 03:41 PM   #2 (permalink)
Well I've had mine 4 months and I have almost the exact oposite. My windows are way too loose. I think I'll yank the door panel this weeekend and take a look at the channel. I thin I remember that the hard to rolll up windows is caused by a breakdown of the channel lining that catches the window, and make it hard to roll up or down.
Old 08-29-2000, 06:12 PM   #3 (permalink)
I had the same problem with my '91 NX just after I bought it. I took off the door panel and the plastic sheet underneath just a little. At the bottom of the door a screw was out of the rollup mechanism. I just put in a new screw and it was like new. I also found the original window sticker stuffed down into the door like the guy just rolled down the window and the sticker was gone when he rolled it back up. I think the previous owner was a dork.
Old 08-29-2000, 11:26 PM   #4 (permalink)
pwnd
Bowlcut's Avatar
Its the classic, classic syndrome. the channel tears and the rubber rubs hard on the window. take the door apart and you can fix it by either replacing it or cutting the tore part. i just live with mine check the archives on se-r.net and the faq there its all explained in there
Old 08-30-2000, 04:16 AM   #5 (permalink)
91ser_driver
Thanks for all the suggestions. I guess I have my project for this weekend.
Old 09-11-2000, 11:21 PM   #6 (permalink)
just bought a 91 ser and ive got the same problem. thanks for the info.
Old 09-26-2000, 08:41 PM   #7 (permalink)
bla bla bla
just knock em' out and put that NASCAR mesh crap in there. or better yet, just Dukes of Hazzard it
Old 10-08-2000, 09:19 PM   #8 (permalink)
merely a flesh wound
chriscar's Avatar
How did you guys make out with the window fix. My 92 has the same problem. What I do is using my left hand, start to roll the window up to the point where is sticks, then grab the glass near the top, at the point where it angles down, and oull it backwards. It moves back a good 1 1/2 to 2 inches.
Chris Scarpulla
92 SE-R
Old 10-22-2000, 04:09 AM   #9 (permalink)
Well I just did mine last weekend. All went pretty good. I also had the window track popout. I just readjusted the travel and window placement while I had the door panel off. Works good now and no more wind noise.
