Old 10-31-2000, 12:48 AM   #1 (permalink)
My car vibrates at speeds over 80mph
Have any of you guys had this problem. As soon as I hit about 80 going down the freeway, the entire front of the car starts to vibrate really badly. Any ideas on where to look for what might be causing it?
It's not the alignment, since I just got it aligned last week and it did not solve the problem.
Old 10-31-2000, 01:11 AM   #2 (permalink)
I would think your tires need rebalanced. Try to put you back wheels in the front and see if that fixes it. If you still get it I woul still go get all your tires balanced just to be sure. That is most likely the cause.
MarC SE-R
Old 10-31-2000, 01:54 AM   #3 (permalink)
I drive a Honda too.
That was the problem on my G20 when I first got it. I had new tires put on and it was solved.
kris is offline   Reply With Quote
Old 10-31-2000, 06:40 AM   #4 (permalink)
SE-R Old school Player!
yeah, get the wheels high speed balanced at a good flat fix joint with the high speed wheel balancing machine and it should be on the money unless you have a bent rim.
redman007 is offline   Reply With Quote
Old 10-31-2000, 08:51 AM   #5 (permalink)
pwnd
Yea Im betting wheel out of balance. Other things that could be it are, flat spoted tire or maybe warped rotors. I had a warped rotor it shook my whole car at 80+ but not that bad at slower speeds. And after fixing that it sorta went away which I believe to also have an out of balance tire, then I flat spoted the tires while showing off the new brakes.
Old 10-31-2000, 08:21 PM   #6 (permalink)
Sounds like a good excuse to get some new tires I know the alignment was way off when I got the car, so the tires did wear unevenly.
