white wire looks like. just make sure when you rev the engine the lights light up one after the other very fast and then when the rpms go down so do the lghts then you have it right. hope I didn't confuse you the 02 is the best splice for it more accurate reading also if the 02 sensor is more than 5 years old and the a/f meter is not brightly lit it means you should get another 02 sensor, accurate and saves you some gas too!
[Edited by redman007 (11-02-2000 at 11:49 PM).]
