sr20ve and Type R if there both have just bolts on and cams im sure the VE can take the Type R anyday. I ran 14.5 with mine and i only got bolts on and plus im a BIG guy lolz im sure if i lose some weights ill be in the low 14s and cams will take me to high 13s.
And check all your motor mounts and did you check your clutch when you swap the tranny?
'91 Sentra SE-R - SR20VE 187whp 138wtq, JWT ECU, SAFC II, JWT Pop Charge, DE maf., Ebay 2.5 Header, 2.5 VRS catback, MSD 8969, ACT HD 6 puk sprung disc, Spanking them Honda's all day
