HELP..engine swap
seems that i will HAVE to keep the engine i just bought...
in that case, is it ABSOLUTELY necessary to switch the manifolds off the us-spec to the j-spec engine?...i mean, will the motor work, start up, work insync with the ecu, etc. i know i will have to drill new o2 sensors in the header, etc, but is switching necessary?
i see that some of you guys have done the swap and have kept the JDM stuff on your cars...anyone that has successfully done this please help, and ANY help would be greatly appreciated to make this swap simplier and quicker....thanks
