Old 04-20-2001, 04:27 PM   #1 (permalink)
1/4 MILE/HORSEPOWER CALCULATOR
go to www.wkdtrbo57.bigstep.com . there i have a link to a hp and 1/4 mile calculator. simply type in your car's weight off u go!!! i am trying to promote my site-please help. there are also 30 or so nissan related links.. thanks
Old 04-20-2001, 05:24 PM   #2 (permalink)
**I Y A M Y A S**
That HP one is WAY off. It told me I have 158.19 HP at wheels, 205.65 HP at flywheel
I dont think so.
MarC
MarC is offline   Reply With Quote
Old 04-20-2001, 05:44 PM   #3 (permalink)
well MarC, this is not my calculation-just a link. just out of curiousity-how "off" is the HP one? can u shed some light on it? and also - is the 1/4 mile one off? thanks for looking anyway MarC.. :-)
Old 04-20-2001, 07:11 PM   #4 (permalink)
18 second monster
1hp = 550lb 1ft 1second...
i guess thats assuming 1:1 gear ratio and 15% driveline loss...
Limited Slip is offline   Reply With Quote
Old 04-20-2001, 07:13 PM   #5 (permalink)
A quarter-mile calculator should really calculate trap speed, not ET (trap speeds are far more consistent).
The following formula is used for many such calculators:
HP = Weight (lbs) x (Trap Speed (mph) / 234) ^ 3
Pit_Viper is offline   Reply With Quote
Old 04-20-2001, 07:25 PM   #6 (permalink)
Autox Junkie
<font face="Verdana, Arial" size="2">1hp = 550lb 1ft 1second...
i guess thats assuming 1:1 gear ratio and 15% driveline loss...</font>
Actually, horsepower is derived directly from torque. That's why on a dyno chart the HP and Torque curves cross at the exact same point every time. I can dig up a HP vs Torque article if you want, it's sort of a tricky subject and even though I've read a lot about it I don't feel like I know enough to explain it.
Paul
'92 NX2000 w/ mods
Scarpa is offline   Reply With Quote
Old 04-20-2001, 11:49 PM   #7 (permalink)
18 second monster
<font face="Verdana, Arial" size="2">Originally posted by Scarpa:
</font>
you got me all wrong, i just gave out the definition for the unit horsepower. i mentioned that those trap-speed calculators probably assumes that there is a 15% parasitic loss (through drivetrain) and that all the crank is hooked up to wheels at axles at 1:1 ratio.
hp is a calculated number from torque and engine speed. hp = torque*rpm/5252
