Old 09-13-2001, 02:04 PM   #1 (permalink)
WASHED UP
hi mike ..well im not to far from u i live in hempstead... so if u ever **** meet up just ask... well as for thr clutch u need a hd/PP and street disk will hole enough hp
Old 09-13-2001, 02:09 PM   #2 (permalink)
I have been very pleased with my JWT pressure plate and OEM disk. I also changed the flywheel at the same time to a lightened JWT unit. The only criticism I can think of is the pedal is very soft, but the clutch is very strong.
On the other hand, when I was researching which clutch I was going to buy I read a lot of negative feedback concerning the ACT clutch. But I'm unable to recall specifics but many of the complaints concerned reliability. YMMV.
Edit: What I really meant to say
93 SE-R JWT S3 Cams, JWT ECU, JWT Pop-Charger, HS Header,RT Cat, HKS exhaust, Hypercoils, KYB-AGX, ST Sways, N-Tech Brace, SMC SS.
[This message has been edited by Andrew (edited 09-14-2001).]
Andrew is offline   Reply With Quote
Old 09-13-2001, 02:14 PM   #3 (permalink)
My Car is My Mistress
Not to sure what that means hd/PP (something/pressure plate) and where can I get it? Thanks for the offer of meeting up. I think we should sometime soon.
sr20deMike is offline   Reply With Quote
Old 09-13-2001, 02:39 PM   #4 (permalink)
WASHED UP
heavy duty/ pressure plate=hd/pp.. i think thats best for ur needs..by ur mods
and for turbo there is extreme pressure plate
Old 09-13-2001, 04:29 PM   #5 (permalink)
Fiber Images trunk lid :)
I have the ACT clutch in my 91 with a clutch master lightend flywheel the pedal is soft but lets out at the floor and grabs like a M.F. I'm very happy with this set up.
91 SE-R Stillen header,HKS/Greddy catback,Nology coil/wires,ACT clutch,Clutch Masters flywheel,CAI,Energy motor mounts,Stillen S/T shifter and still not fast enough...
91SE-R is offline   Reply With Quote
Old 09-14-2001, 01:40 AM   #6 (permalink)
act clutch kits
Hello,
I am new to this list but not new to the ser world. I have owned my 92 white classic for about three years. It's about that time to change the clutch. I think I have it narrowed down to act clutch kit# NX9-HD00. Is anybody using this or any other suggestions?
Thanks,
Mike
92ser cai/h/e/ecu
[This message has been edited by sr20deMike (edited 09-13-2001).]
Old 09-14-2001, 11:44 PM   #7 (permalink)
When I had my 1.6L I had a ACT clutch with the stock flywheel lightened and have had it on for two years no problem. When I got my 92 se-r I bought a ACT clutch and bought that lightened flywheel from zex and works like it is a stock clutch but when you rev it up and let go or even shift at high rpms you really feel the difference and for the price it is just a little bit if not less that a oem clutch. Well worth the money
Old 09-19-2001, 04:04 PM   #8 (permalink)
They're just cones!
I'm really hard on my car, and wore out my clutch in 70k miles, wore out as in the rivets were wearing. I bought my ACT setup (Heavy duty pressure plate and Street/strip disk) and have had it in for 25,000 miles. So far, I absolutely love it. The pedal is a bit firmer, but I was used to it in a week, and actually prefer it. My car isn't very fast, but I can chirp third. It's super smooth engaging, too. I've adjusted it once so far, and not very much, so I think I'm getting pretty good wear. My only complaint is that it took forever to actually get. I'll heartily recommend it.
-=Matt=- 97 SE-R 94,000smiles+, POP, custom 2.25" exhaust, ACT, Shifter, ST sways, AV22VFs (new!)
Driven97 is offline   Reply With Quote
Old 09-19-2001, 07:44 PM   #9 (permalink)
bla bla bla
I like mine too, but I have broke the shift arm twice in it, but it is welded now, so hopefully no more breaky breaky for the tranny.
Old 09-19-2001, 11:01 PM   #10 (permalink)
SR20 Enthusiast
I don't know about you guys. I have been having a bitch of time with my ACT. It engages off the floor. Fine. I have problems getting it into gear most of the time. Not fine. After extended driving, I can barely get it into gear. Anyone have any suggestions. I have had this problem since day 1. I have changed the clutch cable upon installation 6000 miles ago. I have had this problem since day one. Please guys I need help.
dougnosser is offline   Reply With Quote
Old 09-20-2001, 03:11 PM   #11 (permalink)
They're just cones!
Dude, no way, I broke a withdrawal lever too, but I thought it was a fluke. Oh well, I guess I'll just put in a nice flywheel and weld it when this one goes. I wonder who else has had this problem?
dougnosser, it sounds like yours is out of adjustment, and it may not be disengaging all the way. The adjustment is backwards, to make it grip further from the floor you actually -tighten- the cable. Try that, it may work wonders.
Old 09-20-2001, 05:46 PM   #12 (permalink)
SR20 Enthusiast
When I first installed my ACT I broke a withdrawl lever too!
98 200SX SE-R, CAI, Greedy Exhaust, JWT Motor Mounts, Pullies, Nismo fuel press.reg, JWT C1 cams and JWT gears, Valve Springs and Titanium Retainers, ACT HD/PP, Clutchmasters Flywheel, JWT Computer,Bored Airflow Meter.
Old 09-20-2001, 08:12 PM   #13 (permalink)
egg-less
OK, anyone with a new ACT clutch (sounds like there are a few of us), LISTEN UP!
I just did the washer in the big black rubber grommet trick, and BOY IS MY CAR FUN AGAIN! I have a temporary washer (cut from an old magnet sheet) in there now, *** I could find a metal washer with a big enough hole. I have another idea that I am going to try tomorrow. I'll let you know if it works. If it does, it'll cost ya a quarter at Lowe's.
I thought about the concerns people had with stretching the cable. The way I see, you are adding maybe an 1/8 inch to the housing (effectively). Have you seen the thickness of that cable??? At the very worst, you are decreasing the amount of time it takes to wear out the clutch cable. After nine years, I'm only on my third and it takes maybe a half hour to replace?
NOW, QUIT COMPLAINING AND PUT THE DAMN WASHER IN THERE!!!! SHEESH, ALREADY!!!!
aknapp is offline   Reply With Quote
Old 09-23-2001, 10:37 AM   #14 (permalink)
SR20 Enthusiast
OK, the results are..........amazing. The clutch has never felt better. No syptoms of bad pedal feel. We put a new clutch cable in just to be sure. It was still a little "gritty" when you pushed the pedal. Put some washers in by the black gromet. Viola! The car is fun again. I would like to personal thank Charlie in Boynton for your help sir. He has a pretty sweet 98 ser also. I would recommend this trick to anyone who hasn't done it. I went for a long 2 hr drive last night to see if any of the old problems would show it's ugly face and nothing. I'm very happy. Once again, thank all you guys for your help.
Old 09-24-2001, 11:58 AM   #15 (permalink)
bla bla bla
ya, try breaking it twice................. just weld a piece of 1/4 inch steel on top of it and go for it. I just drive around with a extra clutch cable in the trunk now.
Old 09-30-2001, 07:18 PM   #16 (permalink)
Went with the act clutch kit from my original post. So far love it. Have put about 80 miles on it and can't wait to put a few more miles on it so I can beat it. Will be at hamptons raceway (Long Island New York) on friday if anybody would like to join. That includes you to kesi24.
92ser h/i/e ecu and some other goodies
Old 10-01-2001, 07:17 PM   #17 (permalink)
Power to spare...
<font face="Verdana, Arial" size="2">Originally posted by dougnosser:
</font>
Can you describe this method some more? I don't understand exactly where and what you are talking about. (I have just bolted my act clutch kit on my flywheel)
Also, how exactly are you guys welding the arm? Where are you welding it? Wouldn't this prevent it from being removed from the tranny in the future?
Thomas Reynolds is offline   Reply With Quote
