» Auto Resources
Find new Nissan car reviews on Nissan Maxima, Nissan 350Z, and more. View pictures and guides on Nissan cars like a Nissan Altima.
» Sponsor Links
»Garage Storage and Cabinets
Old 05-01-2003, 09:50 PM   #1 (permalink)
What does it take to get NX2K Brakes under the Stock b13 wheels?
I already did a search and could not find any solid answers?
I have heard that the brakes won't fit under a b13 wheel and I have heard that they will if you grind off a little of the caliper.
What is the case? If you can grind the caliper where do you grind it at to get the brakes under the car.
pimpm3 is offline   Reply With Quote
Old 05-01-2003, 10:04 PM   #2 (permalink)
wait...i have a honda?
NismoSER's Avatar
Trader Rating: 17 (100%)
You need these:
http://www.sr20deforum.com/showthrea...threadid=42624
Otherwise, you grind off the face of the caliper that well, faces the back of the wheel. The problem is that the stock SE-R wheels are not wide enough to accomodate the bigger calipers.
Chris
'91 VVL-powered SE-RSOLD
'04 G35 6MT
'99 CBR600 F4
Old 05-01-2003, 10:32 PM   #3 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Trader Rating: 24 (100%)
They fit fine, but you do have to grind them. Forum member Bowlcut had a scanned page from the FSM he colored to show were to grind at one time. I don't know if he still has it. FWIW he's had NX brakes behind stock B13 wheels for several years now.
calum@calumsult.com
Old 05-02-2003, 12:53 PM   #4 (permalink)
I have some pictures of se-r pastor's '94 SE-R with AD22VF ground calipers.
http://www.imagestation.com/album/?id=4290240415&idx=3
[IMG]http://www.imagestation.com/picture/sraid61/p57d3d27005afa5f787532ed73ab31db5/fc3ab1**.jpg[/IMG]
jp314 is offline   Reply With Quote
Old 05-02-2003, 06:12 PM   #5 (permalink)
myprojectB13's Avatar
Trader Rating: 16 (100%)
Try using AD22VF as your search term, there are plenty of posts. Here is a post with some more pics: http://www.sr20deforum.com/showthrea...ghlight=ad22vf
Here are my pics from the install: http://photos.yahoo.com/bc/tropicora...tos.yahoo.com/
Jonathon
Jonathon
1996 G20
1993 SE-R 13.66@101
myprojectB13 is online now   Reply With Quote
Old 05-02-2003, 07:31 PM   #6 (permalink)
Coropate greed hater
Ok, so correct me if I am wrong. When you get ad22vf rotors, you should also get the calipers?
Is this swap going to have any brake bias problems? How much would I be paying for the 2 fronts?
-The Usual Suspects
Old 05-02-2003, 07:52 PM   #7 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Lol, of course you need the calipers. If it was only the rotors this would be the worlds cheapest upgrade. You want calipers, rotors, and torque member thingies. If you buying parts off the shelf, make sure to get loaded calipers as they tend to come with the torque member and single calipers don't. The easiest way is to just buy the parts used from a junkyard or someone parting out an NX. If you do that, depending on condition, rebuild the calipers. For reference, mine were $150 including the NX master cylinder. You don't need the NX master cylinder though, your brake bias will be just fine without it. If you do a search all this plus part numbers has been covered many times before. I think even se-r.net has a bit on it too.
Old 05-02-2003, 08:08 PM   #8 (permalink)
I know I shoulda searched 1st, but because someone made a thread already, I decided to be lazy and just hijack it 4 a little bit. I'm still trying to understand my car, which is easier, I might add, in comparison to the Economics that I am trying to major in.
Old 05-02-2003, 08:41 PM   #9 (permalink)
ClamSlut
Calum's Avatar
Approved vendor
Ekk! A business major, run! j/k :p
Old 05-02-2003, 09:28 PM   #10 (permalink)
Moderator
Harris---
Come down to my place in a month; I am going to do the conversion on my car then. I have the rotors, calipers, torque members and Axis pads.
Curt B. Shumaker
It's time for me to get back into it after nearly 4 years off....
Looking for a low mileage (under 70k), RUST FREE, B13. If you have one, contact me at shumax@yahoo.com
shumax is offline   Reply With Quote
Old 05-03-2003, 09:54 AM   #11 (permalink)
Those are the pics of my calipers, thanks Josh. It is really a trial and error process as you grind them down and fit the wheel. I did it several times then I painted them, put the wheels on, and rolled the car to see where any paint rubbed off then continued grinding. I got my loaded caliper set from Checker and it is a great upgrade. Took the car through the tail of the dragon last month and after 318 curves in 11 miles, the pedal got pretty soft, so I'd look to upgrade the MC soon.
'94 turbo classic--sold
se-r pastor is offline   Reply With Quote
Old 05-03-2003, 04:53 PM   #12 (permalink)
employed again
I ground the calipers until there was nothing left of my grinding wheel. With brand new super-think brake pads, the 5.5" wheels still wouldn't clear, so I popped some 3mm spacers on and all was good...
Longer studs and 5-6mm spacers should do the trick if you don't want to grind.
Matt
MaddMatt is offline   Reply With Quote
Old 05-03-2003, 06:09 PM   #13 (permalink)
How much longer of a stud? And where would one get such studs and spacer? Courtesy?
93 SE-R, PaceSetter header+exhaust(cut and with extra resonator), AEM CAI, Hypercoil 2, AGX, AD22VF brake upgrade, Goodridge SS brake line, silver 15" ATS Comp Lite with 205/50-15Kumho ECSTA 711.
Mada is offline   Reply With Quote
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
