Old 09-22-2003, 09:17 PM   #1 (permalink)
sno
ad22vf assembly.... 56k beware!
**sorry for the large pics**
alright, i may not be the brightest person in the world, but i know i'm not stupid. and something is going on here.... i bought some polished ad22vf calipersand i don't think i have all the parts... here's what i have:
calipers:
mounting arms:
misc hardware:
and that's ALL i have. can someone tell me what i'm missing? i know i'm missing some bolts but i don't know what the correct ones would be. and if anyone can give me some tips on assembling these things, that'd be great too.
sno is offline   Reply With Quote
Old 09-22-2003, 09:32 PM   #2 (permalink)
Professor Dingbat
You should have four bolts, two bigger and two slightly smaller.
Go to the dealer and get all four, it will cost nextto nothing.
Old 09-22-2003, 09:35 PM   #3 (permalink)
You will need a total of four bolts for each caliper. Two are the caliper slid pin things, and two bolt the torque mount to the hub. I THINK you should be able to use the old bolts for the torque mount. The caliper pins im not sure. Oh, and you need brake pads .
Old 09-22-2003, 10:06 PM   #4 (permalink)
merely a flesh wound
chriscar's Avatar
You need the elusive AD22 torque members. Good luck finding them, the only way to buy them is to get a set of loaded rebuilt calipers, and even then, not all brands include them.
Old 09-22-2003, 10:21 PM   #5 (permalink)
chris, look at the second picture
Old 09-22-2003, 10:57 PM   #6 (permalink)
Big Daddy $
What pads do you get for the AD22vf?
'07 Camry SE
GHSER7 is offline   Reply With Quote
Old 09-22-2003, 11:10 PM   #7 (permalink)
chriscar's Avatar
Sheesh, I'll go stand in the corner with my nose to the wall.
Old 09-23-2003, 05:42 AM   #8 (permalink)
sno
i was also given a set of used pads which will be good for breaking in the new slotted roters i'm getting, i didn't think it'd be worth showing a pic of them. i plan on buying a set of non-abrasive pads and some good brake fluid. any recomendations?
Old 09-23-2003, 05:44 AM   #9 (permalink)
sno
any write ups on how the torque mounts connect to the calipers? looking at the bolts that i have there's no threads for it to screw into the mounting arms. i a bit confused...
Old 09-23-2003, 10:31 AM   #10 (permalink)
Professor Dingbat
The slider pins thread into the calipers and go through the torque members where those rubber accordion things are.
AS for pads, what are you looking for in a pad? Axxis ultimates are pretty much the best street pad but they wil be a bit harsher on the rotors that a conventional pad. I am running EBC greenstuff, alot of people bitch about them, but unless you run a roadcourse they will be fine. I've had them for a year and a half with no problems. They fade if you brake from 150mph to 30moh but how often do you do that? If you want a pad that lasts long and is fairly resistant to fade, get genuine nissan.
Old 09-23-2003, 01:33 PM   #11 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
Yeah, you can use the stock bolts for the torque members, you just need a set of slide pins for those calipers. You can get them about any auto parts place.
Brent
coach is online now   Reply With Quote
Old 09-23-2003, 02:39 PM   #12 (permalink)
sno
alright. thanks a lot guys.
