Old 09-28-2003, 02:35 AM   #1 (permalink)
Suspension
What is the suspension like on a classic se-r? Struts on all four corner? I am looking at a car for sale but the suspension has been replaced with aftermarket parts that aren't any good. I would be happy with replacing the parts with stock used se-r pieces I just need to know what to look for and about how much they would cost used.
nitroracer is offline   Reply With Quote
Old 09-28-2003, 02:39 AM   #2 (permalink)
Coropate greed hater
You could have easily found this out with searching. Classics have struts on all four corners.
-The Usual Suspects
Old 09-28-2003, 02:50 AM   #3 (permalink)
Honda Employee...
4-wheel independent suspension, Macpherson struts at all 4 corners. Rear is parallel links with trailing arm linking frame to spindle. The main problem for classics is wheel travel and it's not cheap to solve. Replacing with stock parts may be more expensiove than better aftermarket stuff. Like Harris said, so a lil searchin' for solutions that would work best with your needs.
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
Old 09-28-2003, 02:54 AM   #4 (permalink)
Thanks for the info guys. I was thinking about going to stock parts because this would be a daily driver and possibly encounter snow. So unless I buy a nice set of wheels I don't mind sitting up another inch or two.
