Old 10-03-2004, 10:00 PM   #1 (permalink)
Gas gauge Not Working
The other Night after starting up my car the gas gauge went all the way to the left.
Anyone ever had this happen?
How do I fix it?
SoCalRacer is offline   Reply With Quote
Old 10-04-2004, 07:25 AM   #2 (permalink)
Have you had any work done to the fuel pump recently? The connection for the fuel gauge is right next to the fuel pump connection. Take your rear seat out and remove the access panel. You will see 2 electrical connection plugs. The lower and smaller of the 2 is the fuel gauge connection. See if it has worked it's way loose, or take it off and clean the contacts. If neither of these work, then either the float switch in the tank has gone bad or the actual gauge in the dash has failed.
smithjw is offline   Reply With Quote
Old 10-20-2004, 03:02 PM   #3 (permalink)
I know that this thread is kinda old but just recently my clock display stopped working- The light inside works but nothing else. ould this be a shot gauge cluster or what?
Old 10-20-2004, 10:31 PM   #4 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
Did you fix the gas guage? If not, I have a in-tank sensor and tank top section available.
Old 10-21-2004, 04:31 PM   #5 (permalink)
I didn't do anything to it and it started working again so I guess I did fix it.
But now my clock doesn't display anything.
