are you sure you didnt install the fronts in the rears and the rears in the front. dont feel bad, i did it too. i was all like "dayum this sh*te is slammed" but then i realized the front was so low because it had the rear springs. dah. well hopefully you figure out what is wrong. if not, put like 2 or 3 12"s in the back. it will lower it for you.
92 se-r: sold to paul lopez
new car: 91 turbo b13 253.8 whp
jdm sr20, t25/t28, hks ss bov,jwt s3 cams, 3 pulley set, walbro 255, jwt ecu 3bar, 370cc, clutch master flywheel, act 6 puck clutch with extream pp and some other things too...
i need an upgrade.
