Old 10-12-2004, 05:49 PM   #1 (permalink)
JDM BOOST WHORE
SR20 91 SE-R's Avatar
people w/ grid's
ok what mods do i have to do if i get 15" grids with 195/50/15 tires to fit on my car? any offeset ? do the 16" grids fit properly or do i have to mod them also with the 205/40/16 tires and what offset for the 16's.
SR20 91 SE-R is offline   Reply With Quote
Old 10-14-2004, 01:18 AM   #2 (permalink)
JDM BOOST WHORE
So No Body Has These Rims Or What? Or Just Shy
Old 10-14-2004, 01:47 AM   #3 (permalink)
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
15's should fit fine w/ 195/50/15 tires...
16's "should" fit fine w/ 205/40/16 tires...
IIRC most rota's have a +40mm offset, which is a good fit for our cars. i am in process of picking either new 15" wheels or new 16" wheels. i see plenty of people on the forum running 17" wheels, so i feel i should have little to worrie about with 16's. all this does depend on what suspension you are running.
Avshi750 is offline   Reply With Quote
Old 10-14-2004, 08:01 AM   #4 (permalink)
hasta la victoria siempre
SERfanatic's Avatar
Trader Rating: 147 (100%)
I'm not sure but I think you might have to bore the center of the wheel to fit over the rear hub.
1992 Classic--the rice mobile--
1999 BMW 528i--the family wagon--
1991 SENTRA SE-R PARTOUT GOING ON
http://www.sr20forum.com/mechanical-...-you-need.html
SERfanatic is offline   Reply With Quote
Old 10-14-2004, 01:01 PM   #5 (permalink)
JDM BOOST WHORE
yeah i heard about getting it bored but dose the off set matter? i dont want the rear to rub the rear strut.
Old 10-14-2004, 06:21 PM   #6 (permalink)
SERfanatic's Avatar
I believe the offset on them is +38 so you should be ok. The factory offset is +40 on 14X6.5 or 14X7 wheels.
Old 10-23-2004, 12:09 AM   #7 (permalink)
I have 17" and have a 1.4" drop w/ ebach springs and KYB gas struts and have no problems. No camber. You can put up to 19" w/ right off set an stock height.
smokenSR20 is offline   Reply With Quote
Old 10-23-2004, 05:06 PM   #8 (permalink)
JDM BOOST WHORE
thats why i was asking about the offset. i dont wanna have problems when i get them.
Old 10-24-2004, 08:07 PM   #9 (permalink)
Cheap Bastard
narcotix's Avatar
No probs with my 15" grids. No need to bore out since Nissan hubs are actually smaller by a few millimeters. Some suggested hubcentric rings, but if you carefully tighten your lugs in an even torques pattern, you'll be fine and centered.
And I have 205/15 Toyo's on it and had just very *slight* rubbing on the rear strut body.
"Better living through chemistry...."
narcotix is offline   Reply With Quote
Old 10-25-2004, 12:54 PM   #10 (permalink)
JDM BOOST WHORE
Whats Offset Are Your Rims? 15.6 Rims? With The 205's
Old 10-25-2004, 01:31 PM   #11 (permalink)
Cheap Bastard
narcotix's Avatar
38mm offset. If anything, use H&R 5mm spacers in the rear and you won't have problems.
You can check out the little picutres on the JLB website:
http://www.jlbmotorsports.com/RotaCnMguide.html
There you can see the pic of my B13 wih FRSB Grids on it.
