Old 10-18-2004, 09:50 PM   #1 (permalink)
which engine do I have?
My stepson's 93 threw a rod, the bottom #1 rod (left of the dipstick) was poking out of the block!! Anyway, we ordered engine from soshin. I just noticed today that the new engine has no O2 sensor hole in the exhaust manifold. We had to swap in the old exhaust and intake manifold. They're both highport. My question is, what year is this engine? I thought all B13 engine has O2 sensor hookup in the exhaust. Anyway I can find out what engine I have by reading off some serial number? Just very curious. Thank.
93 SE-R, PaceSetter header+exhaust(cut and with extra resonator), AEM CAI, Hypercoil 2, AGX, AD22VF brake upgrade, Goodridge SS brake line, silver 15" ATS Comp Lite with 205/50-15Kumho ECSTA 711.
Mada is offline   Reply With Quote
Old 10-19-2004, 11:06 AM   #2 (permalink)
banned
Its the same to what you had before, just jdm It comes with no egr BS, It had no o2 probably cause the car it came out of had a standalone ecu or something...
Urbanracerone-old is offline   Reply With Quote
Old 10-19-2004, 02:08 PM   #3 (permalink)
My SR's are Multiplying!
I believe the exhaust manifold that came on the JDM engine had the O2 sensor in the lower exhaust manifold pipe (the one that goes under the engine). Use your USA-style manifolds. ALso, dont forget to switch over the coolant temp sensors.
Aaron S.
1972 Datsun 510 W/S13 SR20DET
1997 240sx
1991 Sentra SE-R Project: Anti-Bling (SOLD!)
compression is offline   Reply With Quote
Old 10-20-2004, 12:12 AM   #4 (permalink)
4th sr20 and counting..
zipstrips's Avatar
i switch the coolant sensor, and installed my pace header again, no problems with it sense... i kept the jdm intake with no erg and i didnt even throw a code or light that i am aware of....
SHIFT_multiplication!
01. Audi TT 225
98. W10 w/ S4's!
95 Celica, 3SGTE
FOR SALE! PM ME
99. P11 auto $4k
90. Miata $4k
Old 10-28-2004, 10:49 AM   #5 (permalink)
do you switch the sending unit to the gauge or the temp senso to the ecu
if i don't switch the usdm sensor to the jdm motor what will happen?
sillyme is offline   Reply With Quote
Old 10-28-2004, 05:12 PM   #6 (permalink)
Well, the engine is in and seems to run fine. We had to use the old intake manifold. I also noticed something, changing a starter on SR20DE would be a hell of a job with the engine in the car. How the hell does one even get to that second bolt? The new motor seems to run even stronger. Is the JDM motor stronger? If so, by how much?
Old 10-28-2004, 05:45 PM   #7 (permalink)
VE 96 SE-R
You could have the 10:1 motor. Was the exhaust manifold on the jdm motor tubular or cast iron like your stock one?
Robert Sousa
http://i17.photobucket.com/albums/b5...-07meet060.jpg
96 SE-R VE goodness
95 G20, couple bolt ons & JDM goodies
SER96VPEC is offline   Reply With Quote
Old 10-29-2004, 01:29 AM   #8 (permalink)
Hum, it looks like an exhaust manifold.
Old 10-29-2004, 08:05 PM   #9 (permalink)
I love Katamari
is the surface of it bumpy (cast) or smooth (tubular)?
Bjorn is offline   Reply With Quote
