Old 10-28-2004, 05:45 PM   #1 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
Question for anyone with AGX's
I am missing one of the little color coded plastic clips that are used to adjust the fronts. The other one has the colors but the #'s are rubbed out. Can someone do me a favor, and check theirs and post the equivalent #'s that go with each color?
I've got both set on green, whatever that means. Thanks, Ben
1992 SE-R 'Fasty' Mods and mods in boxes. Ready for more boost, or more vvl.
Old 10-29-2004, 01:30 AM   #2 (permalink)
I'll check in the morning then get back to ya, unless someone got to it first.
93 SE-R, PaceSetter header+exhaust(cut and with extra resonator), AEM CAI, Hypercoil 2, AGX, AD22VF brake upgrade, Goodridge SS brake line, silver 15" ATS Comp Lite with 205/50-15Kumho ECSTA 711.
Mada is offline   Reply With Quote
Old 10-31-2004, 01:51 PM   #3 (permalink)
Your dead Twinkie
Anyone?
Old 10-31-2004, 01:58 PM   #4 (permalink)
Trader Rating: 27 (100%)
1 white
2 yellow
3 green
4 red
I just noticed mine are starting to rub off too.
Kevin
1992 SE-R T3/T4
1996 SE-R VE??
Coasttocoastusa.com
93BlackSE-R is offline   Reply With Quote
Old 10-31-2004, 09:12 PM   #5 (permalink)
Your dead Twinkie
Originally Posted by 93BlackSE-R
1 white
2 yellow
3 green
4 red
Thanks I'll change mine tomorrow. I think green is a bit much for daily driving. I thought the were a bit stiff up front.
Old 10-31-2004, 10:22 PM   #6 (permalink)
EECS Nerd.
i use 2 up front, 4 in the rear
with crappy berkeley roads, this is a wonderful setup.
Old 10-31-2004, 10:38 PM   #7 (permalink)
The Groove Master
Rittmeister's Avatar
KYB will actually send you a new little adjuster assembly (the black disc with the colors/numbers, and the adjuster screw) for free. One of mine disappeared, I called them and they sent me a new one.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Old 11-01-2004, 08:33 AM   #8 (permalink)
Your dead Twinkie
That's good news. Good companies stand behind these little bits of misc underdesigned pieces. Hotshot for evereything people say has been really good to me in this regard.
I've got my fronts on 1, and the rears on 2 right now. Rear has been fine, so far, but the fronts seemed a bit stiffer than I remembered from the last tiem I ran AGX.
Old 11-01-2004, 11:52 AM   #9 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
If 2 front 4 rear is the same as GR2's which are OEM replacement, then those settings coupled with higher spring rates is going to ruin your AGX's. You have to run firmer settings than that if you don't want to ruin them.
- Rob
Old 11-02-2004, 01:35 AM   #10 (permalink)
Your dead Twinkie
Yeah, but 1f 2r feels nice. These springs really are stock-ish over normal stuff, but 1,2 is under-damping it. I'll probably change it to that in a few days. 3F was definitely too much for daily operation. Much different
If I had nice Koni bumpers I might risk the lower setings. Any idea which might be the best? I've seen ES, koni, JIC, and KYB bump-stops.
