Old 11-29-2001, 06:01 PM   #1 (permalink)
HYEST
What is a DET?
sorry im new here. i heard it being talked about a few times.
Old 11-29-2001, 06:13 PM   #2 (permalink)
bla bla bla
same thing as a sr20de but it has a turbo, intercooler, diffrent pistons, rods, ect, ect. basically a bad ass motor. www.google.com
2003 VW gti 1.8t
72 Datsun 510-sold
Old 11-29-2001, 06:42 PM   #3 (permalink)
SE-R-less
There are several versions of both the SR20DE and the SR20DET (Remember 'T' is for Turbo).
While the engines are similar in most respects there are several differences.
Mike Kojima commented:
Here are the differences between the DET and the DE:
The DET has oil squirter piston coolers
The DET has a bigger oil pump.
The DET has a different front pulley.
The DET has lower compression pistons (8.3:1 vs 9.5:1).
The DET has bigger injectors.
The DET has direct ignition.
The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end.
The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
The GTi-R DET has individual Throttle body injection.
The GTi-R DET has stronger main cap bolts.
The GTi-R DET has beefier rods.
Just about all the parts between a DET and a DE interchange.
--This info can be found at www.se-r.net at the "car info" link.
Kevin
01 Saturn SL1 (love that plastic in the city!)
Sold:
93 Classic w/ advanced timing, Stillen POP and Header
kpw97 is offline   Reply With Quote
