Old 12-02-2001, 06:11 PM   #1 (permalink)
Trunk problems
The lever wont work i pull it and i get nothing does the lever go thrpought to underneeth the car or just un the carpet. i think its mights bes broken.
93 se-r
dweed is offline   Reply With Quote
Old 12-02-2001, 06:31 PM   #2 (permalink)
Barney will pwn you
Hey this Jackie Chan off of 3rdshift with the silver beast before it got crushed. Anyways prolly the cable snapped or something to release the trunk. I think you can some classic sentras in Cophers. You might wanna try there first.
Turbo Barney
SERracer01 is offline   Reply With Quote
Old 12-02-2001, 07:20 PM   #3 (permalink)
NISSAN SOLDIER
Join the club!!!
Just use your key.
Old 12-02-2001, 08:20 PM   #4 (permalink)
Trader Rating: 102 (100%)
there is a little lever right where the latch is in the trunk check how it is, its like a valet option thing, so they cant get in your trunk. if thats not it, then your cable is probably broken.
good luck
Old 12-02-2001, 08:23 PM   #5 (permalink)
NISSAN SOLDIER
you think you have trunk problems!!!
Old 12-03-2001, 02:48 AM   #6 (permalink)
School Sucks!!
Dude, first try holding the lever up with something and attempt to open the trunk. If that doesn't work, it means your cable is snapped.(if you have the gas release on that same lever like most of us, that will probably not work either if the problem is a snapped cable). But if holding the lever and opening the trunk works for you like it did for me, then the problem is on the trunk lock and there is an easy fix. Open your trunk, remove the trims on the bottom hatch locking mechanism, and locate the two bolts that hold the locking bracket and loosen and raise the bracket then tighten it back. (you might have to do it a couple of times until you get it right.)
Hope this helps,
Nick
http://www.sr20de.org/images/images/...000/n24cut.jpg
1993 Nx2000 BB DET, PS short shifter, ACT HD s/s clutch, ST front and rear bars, and AGX/Eibach suspension.
1BAD_NX is offline   Reply With Quote
Old 12-03-2001, 11:18 AM   #7 (permalink)
Thanks for the help guys.
Old 12-05-2001, 12:52 PM   #8 (permalink)
BANNED!!eleven
on my old maxima the latch was a little off and it made the trunk release button not work. maybe the problems something like that.
Stirpicult is offline   Reply With Quote
Old 12-05-2001, 07:15 PM   #9 (permalink)
I drive a race car again!
SmoothDaddy,
You have have way to much time on your hands.
Go outside and get some sun!
Steve
#6 ITA - 138,557 miles of bent-up motor, 50K of the new stuff
Indy Region SCCA
http://img.photobucket.com/albums/v3...5/MidOhio2.jpg
Racerlinn is offline   Reply With Quote
Old 12-05-2001, 08:09 PM   #10 (permalink)
NISSAN SOLDIER
Where do you think I got the bananas!!!!! Outside in the sun!!
Old 12-05-2001, 10:50 PM   #11 (permalink)
Originally posted by SmoothDaddyFig
Join the club!!!
Just use your key.
I don't think that's an appropriate answer to dweed's problem. He posted a legitimate question, and you didn't contribute anything helpful at all.
Also, if you're going to post pictures, please limit there size. Some of us don't have very fast internet connections.
'92 Sentra SE-R
'82 Camaro Z28, ESP autocross car (50% ownership)
slowSER is offline   Reply With Quote
Old 12-06-2001, 11:32 AM   #12 (permalink)
My leaver still works, but the damn spring gets locked in the open position, so you have to get in the trunk and use a screw driver to pop the spring back in place.... since there are 2 springs, my friend decided to take one out, so now I when I open it, I have to hold it open otherwise it will slam shut and crush anything (or anyone's head) that is in it's way!!!!
damn trunk!
neeraj
1994 SE-R
AKA: ECNOBOX
AKA: Red Coffin
Vtec is offline   Reply With Quote
