OK, here's the quick and dirty.
I have two 91s, an SE-R and a G20. This will work for a 91 or 92. If you have a air bag equipped car, you'll have to figure something out. If I had one, I probably could figure it out, but since I don't, I'm not particularly intersted in spending the time. Sorry. I've got too many projects.
Also, with an air bag equipped car, to even use the horn, you have to do the pen spring and nail or other metal piece trick. Or, you could install a wiper (I think) switch from an earlier car in yours (check to make sure it will fit though).
I used a switch from a U12 and have one from an S13. they are the same switch. There is a different intermediate connector, but it doesn't matter.
HUB:
First you must remove the MOMO horn ring. Remove the outer "ring" cast into the hub. I used a die grinder and files. Enlarge the hole for the wires so the intermediate connector will pass through. Be sure the rubber hub cover will hide the hole. Take the horn ring from the OEM wheel. Cut the "shafts" that the OEM ring to the wheel. I attached the OEM ring to the MOMO hub using RTV and a little HD tape around the center of the hub to make for a reasonably tight fit.
SWITCH:
See above for the source. I made a bracket out of 1/4" ABS plastic that I attached the switch to. I drilled and tapped holes in the MOMO wheel spokes to attach the bracket. Since I have a MOMO Runner wheel for both cars, there is a center cover that covers the bolts. For another wheel, you're on your own to figure it out.
I've already done this for my G20. I'll be doing it again soon for my SE-R. I'll try to take some photos and post the procedure either on my own website or on SE-R.net.
George Roffe
91 SE-R (well modded)
http://www.nissport.com
