Old 08-16-2005, 11:50 AM   #1 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
B13/B14 Front BABK in development
Im getting ready to wrap up a BABK GB for the B15/P11 guys here shortly, Im just wondering who would be interested in a set built for the B13/B14 platform. Here are the specs that it would be made to.
My Stuff:
-Matching Hat with hardware
-Dogbone with hardware
-SS Brake lines for front
As with the other BABK kits I make, I only sell what I can produce. Calipers, pads, rotors are all sourced thru other places and you would have to get those on your own.
Ill be building a prototype set reguardless just to have this under my belt, but wondering who would be willing to get in on a group buy for these. Just so you know, GB's of 5 or more are the only way I can keep material prices down by purchasing in quantity.
The last GB price was $475 for my stuff (prices subject to change), plus SS brake lines for the front. So speak up if you think this is a good idea.
Old 08-17-2005, 01:33 AM   #2 (permalink)
Avshi750
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
good price. i would be interested to see the kit.
Avshi750 is offline   Reply With Quote
Old 08-17-2005, 04:42 AM   #3 (permalink)
hpro123
SE-R GREEK
Originally Posted by Yahnozha
My Stuff:
-Two Piece Rotors either 11.75" or 12.19" by .810" thick vented
Old 08-17-2005, 11:10 AM   #4 (permalink)
Yahnozha
yeah, my bad, my stuff just incudes the hat, dogbones, hardware and SS Lines if need be. Youll have to source rotors, but they are cheap, like $30 for plain vented ones.
Old 08-18-2005, 01:12 PM   #5 (permalink)
3BiP
My Stuff:
do me a favour and do products that do not exist like rear kits
SEXY SUPERVISION COMPANY!!!
3BiP is offline   Reply With Quote
Old 08-18-2005, 01:36 PM   #6 (permalink)
Yahnozha
Well you got the maxima upgrade for the rears, and the market for a $1000 rear brake kit is limited at best. Plus with aftermarket calipers youll lose the e-brake.
If you want to committ and pay for a rear kit, ill develop it, but its not gonna be cheap.
Old 08-18-2005, 06:59 PM   #7 (permalink)
3BiP
fastbrakes.com is pretty good and keept me happy with their kit
when i got my babk kit for front and rear maxima i was more then pleased with services they offered
Old 08-19-2005, 04:38 AM   #8 (permalink)
peter96
Over, Fold, Change
I looked on their site and only saw maxima rotors for sale for the rear. 90/pair
No calipers/member? What did you get from them brake wise? How much?
was it just the maxima upgrade I can buy at pepboys? Or do they have a rear kit?
As for the front, 60 on rotors, 260-360 (from magnumracing site) for a pair of 4 piston wildwood calipers, 60 on pads comes out 100 to 200 less than fastbrakes. Why would you pay more?
You know, I just realized the pads and rotors are cheaper to replace for these BABK than my AD22s. That's pretty funny, Ferrari brakes with Sentra maintenance costs
Peter J
96 SE-R
peter96 is offline   Reply With Quote
Old 08-20-2005, 01:40 AM   #9 (permalink)
Corrosion
its dubtastic
the BABK is TOP notch =)
i have had first hand contact with both fast brakes and p@'s work. the differences are night and day! and for the price it will cost to get the complete BABK you can not go wrong.
but i too want a rear BABK come on p@ please......
Dan
NYCGs, the biggest G20 club in the US!
Corrosion is offline   Reply With Quote
Old 08-30-2005, 08:32 AM   #10 (permalink)
ssnh
is there a parts list available, for the parts which are not included in the b13 kit?
ssnh is offline   Reply With Quote
Old 08-30-2005, 11:36 AM   #11 (permalink)
Yahnozha
You can get any of the Wilwood Dynalite seriers made for .810" disk thickness. I prefer the forged Dynalites due to forging process. The Narrow Mount Dynalite WILL NOT WORK with my dogbone.
Forged Dynalites with 5.25" centered mounting lugs
120-6806 - Forged Dynalite 1.38" pistons .81" Disc - $117.99 each
120-6811 - Forged Dynalite 1.63" pistons .81" Disc - $117.99 each
120-6816 - Forged Dynalite 1.75" pistons .81" Disc - $117.99 each
Billet Dynalite caliper
120-5005 - Billet Dynalite 1.38" pistons .81" Disc - $131.74 each
120-4937-P - Billet Dynalite (Polished only) 1.63" pistons .81" Disc - $180.35 each
120-4997 - Billet Dynalite 1.75" pistons .81" Disc - $131.74 each
The Rotors you have several choices, the best and probably cheapest are the plain vented UL-32 series with a 8 hole pattern 7" on center, but any Wilwood rotor that is .81" thick and an 8 x 7" hole pattern will work, these are a few of them.
Ultra-Light UL and ULHP straight vane rotors (1.25 thick shown)
160-0277 UL32 Vented Iron 12.19" x .810 - 8 on 7" - $32.99 each
160-0471 UL32 Vented Iron 11.75" x .810 - 8 on 7" - $30.99 each
High Precision Turned Rotors
160-5843 UL32 HP Vented Iron 12.19" x .810 - 8 on 7" - $69.38 each
160-5841 UL32 HP Vented Iron 11.75" x .810 - 8 on 7" - $69.38 each
ULS - 32 Series Scalloped Rotors
160-8136 UL32 Ventend Iron Scalloped 12.19" x .810 - 8 on 7" - $89.95 each
160-8135 UL32 Ventend Iron Scalloped 11.75" x .810 - 8 on 7" - $89.95 each
ULD - 32 Series Drilled Straight Vane Vented Rotors (1.25" thick shown)
160-5868 UL32 Vented Iron Drilled 12.19" - 8 on 7" - $51.99 each
160-5863 UL32 Vented Iron Drilled 11.75" - 8 on 7" - $49.99 each
SRP Drilled Performance Rotors
160-7101 Vented Iron RH-SRP Drilled 11.75" x .810 - 8 on 7" - $124.93 each
160-7102 Vented Iron LH-SRP Drilled 11.75" x .810 - 8 on 7" - $124.93 each
160-7103 Vented Iron RH-SRP Drilled 12.19" x .810 - 8 on 7" - $124.93 each
160-7104 Vented Iron LH-SRP Drilled 12.19" x .810 - 8 on 7" - $124.93 each
Pads, any of the 7112 series of pads, check with Wilwood for the best pad for your application. Personally, I run the Q compound daily, and the H compound on the track with the G.
Also, double check these part numbers for yourself. www.wilwood.com , prices provided by www.precisionbrakes.com
Hope that answers your question, there are a lot of options to choose from.
Old 09-05-2005, 04:18 AM   #12 (permalink)
Nizmonik SE-R
GT30R'd Up
Ok, Im interested in picking a one of these Brake kits for my B14 but Im getting a lil confused now....is it:
$475 (Your Hardware which includes Two Piece Rotors either 11.75" or 12.19" by .810" thick vented, Matching Hat with hardware, Dogbone with hardware and SS lines)
plus
A pair of 120-6816 - Forged Dynalite 1.75" pistons .81" Disc - $117.99 each x 2
Total = $710.98 (Not including Pads)
Correct me if Im wrong please, Im interested in finding out the total cost im looking at.
Allan
96 SE-R GT30R'd Up
07 G35S Sedan
Nizmonik SE-R is offline   Reply With Quote
Old 09-05-2005, 01:03 PM   #13 (permalink)
Yahnozha
okay I edited my fist post finally. Here it is agin..
My stuff
You need to buy this stuff elsewhere
-Pads
-Rotors
-Calipers
Please note: The $475 price + shipping is only if I have 5 or more buyers (and thats subject to change due to material price/gas fluctuation) IF you want to buy a single kit look for the price of my stuff to be around $600
Old 09-06-2005, 10:19 PM   #14 (permalink)
Fosters I am a moderator
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
P@,
Are you thinking/planning for this setup to clear 15" wheels? Or only w/ spacers, etc?
Also, how's the website coming that shows all of your excellent products?
Thanks,
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 09-07-2005, 03:01 AM   #15 (permalink)
NoClassic
stirring but plain-faced
What material are the hat and "dogbone" going to be made of?
NoClassic is offline   Reply With Quote
Old 09-07-2005, 08:44 AM   #16 (permalink)
Yahnozha
hey Josh...I dont know what spacer requrirements Ill need with this setup. On the P11, i run into interferrence with the caliper with the stock 15" rims. Dont know if ill have that issue with the B13/14 and stock rims or not...thats with a 11.75" rotor. The website is being worked on...
The hats are 7075-T6 and dogbones are 6061-T6
Old 09-08-2005, 04:00 PM   #17 (permalink)
DEAD SE-RIOUS
SR20DEEP N.Y.C.
what is the fastbrakes website?
SR20DEEP N.Y.C.
"RUTH'LESS"
TOPPSRACING
http://www.imagestation.com/picture/...3/fcb9c837.jpg
DEAD SE-RIOUS is offline   Reply With Quote
Old 09-08-2005, 04:30 PM   #18 (permalink)
paNX2K&SE-R
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 65 (100%)
Sweet I'm glad you got a chance to work on this Pat
15" wheels should be fine and some will even work without a spacer. I know Jim/Jason ran/runs 15x7 Volk TE37s with the old (same size) SMC BABK without a spacer.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 09-08-2005, 04:44 PM   #19 (permalink)
Yahnozha
try some searching....sheesh...
Yeah, the P11 - 11.75" rotor/caliper combo, will just barely squeeze under a stock P11 15" rim if you shave part of the caliper....but its super tight....Im sure any after market rim will have gobs of clearance.
