Old 12-05-2005, 11:26 AM   #1 (permalink)
shift!_now?
Trader Rating: 15 (94%)
rear camber plates?
can you make camber plates for b13 rear coilovers???
ALL FAST CARS GO TO HEAVEN!
GAINING RESPECT ONE PSI @A TIME!
my stuff for sale
'91 SE-R.... SR?DE-t-----rOAd & TrACk
JUN'S GARAGE...We call this Non-Weak Sauce Racing
grizz00 is offline   Reply With Quote
Old 12-05-2005, 11:33 AM   #2 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
I guess I could...I dont have a B13 handy for test fitting ***.
Old 12-05-2005, 05:40 PM   #3 (permalink)
shift!_now?
damn .....how can i help?
Old 05-24-2007, 02:04 PM   #4 (permalink)
Hey Man this would be a great thing to put out. Seeing as nobody makes a bolt up rear camber kit. Also would be handy as the Cusco rear plates need to be shaved to fit the b13 and they are not compatible with the Progress coilovers.
BUMP FOR RENEWED Interest.
Old 05-24-2007, 03:53 PM   #5 (permalink)
Well Ive got a B13 now, so this might be a possiblility, have any reference photos for me to gander at?
Old 05-24-2007, 04:24 PM   #6 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
There is a thread about htis in the racing section. I will try and find it!
Brent
coach is online now   Reply With Quote
Old 05-24-2007, 04:43 PM   #7 (permalink)
rex
You mean this one?
http://www.sr20forum.com/road-racing...ar-camber.html
I would be interested in some if they get made.
rex is offline   Reply With Quote
Old 05-24-2007, 04:56 PM   #8 (permalink)
Yeah Dude I'm in too. Just make sure they are quality as I would need them for a race track environment. Most likely I'm going to go with a progress coilover setup so something that would work flawlessly with the progress coilovers would be great.
Personally for me I'd like something that does not need any cutting to the cars sheet metal. Top mount or bottom mount does not matter. Whatever works best.
I'd say if you got your hands on some Ground control camber plates or the cusco back plates it would be a great way to the brainstorming started.
Old 05-24-2007, 05:27 PM   #9 (permalink)
Well, two ways to approach this, aluminium or steel. Either way, ill need to get a poll on how you guys are mounting the top plates (stock/aftermarket), or at least some reference photos of what you currently have.
Old 05-24-2007, 06:32 PM   #10 (permalink)
Tired!
coach's Avatar
basically, people shave the cusco front plates to fit in the rear. That gives you an idea. The issue is people will have to cut the tower a bit to get the adjustments
I will try and find pics, but no luck so far.
Brent
Old 05-24-2007, 07:02 PM   #11 (permalink)
I do believe CUsco makes a pulsar gti-R rear plate. Dunno if its adjustable or not. GOing to research.
I checked on a cusco catalog. There is a rear plate listed. Adjustable and non adjustable.
Here are the part numbers.
212 420 A, 212 421 AS.
I believe the 420A is the adjustable model.
So I'm guessing the adjustable rear plate would be a good item to work off of.
Old 05-24-2007, 08:35 PM   #12 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Ooooooo very interesting, subscribing to this thread!
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 05-28-2007, 03:10 PM   #13 (permalink)
You want how many lengths
I ran the same Cusco rear adjustable camber plates on my NX; and yes the plates do need to be shaved to fit the B13 strut tower. In my opinion, they work really well and my NX gained about an inch of height in the rear, which is what I was looking for. I found my NX to perform much better at near stock ride height, I did not enjoy my NX when it was dropped to the ground like everyone else.
93' NX2000 - currently parting out
NEW PROJECT COMING SOON!
LONG LIVE THE SR20!!
DRIFTING THE ABSTRACT!!
nxgripspec is offline   Reply With Quote
Old 05-29-2007, 02:01 PM   #14 (permalink)
man, if the cusco plates work with little modification, Honesly I would just go with them. ITs going to be tough to beat that $200ish price for the cusco plates.
Old 05-29-2007, 03:02 PM   #15 (permalink)
www.japanparts.com is the website I goto for hard to find parts such as the Cusco plates. They usually have them in stock brand new; on a good day depending on how the exchange rate is, you can get them for under $200. They have great customer service and nice incentives if you become a member!
Old 05-29-2007, 04:25 PM   #16 (permalink)
www.FAIRTAX.org
Anyone have a pic of these plates installed?
Old 06-13-2007, 01:25 AM   #17 (permalink)
Trader Rating: 16 (100%)
I have modified B13 Cuscos on my B13 in the rear.
I'll see if I can get some pics some time. Basically you redrill the studs 90 degrees out and cut off one edge to clear the inner strut tower. Without notching up top I think you can gain about a degree or so of negative camber.
OTOH, you could always slot the strut or use the Ingalls adustable lower links to easily dial in toe/camber.
_SHig
SHigSpeed is offline   Reply With Quote
Old 06-13-2007, 01:29 AM   #18 (permalink)
_SHig
P.S. Sorry P@ if I'm stepping on your toes here, but if you're gonna pass on this project, I have a couple of sets of FIXED offset negative camber adding rear pillowball mounts lying around waiting to be assembled. I think they're about a -1.5 ish camber change. I built a small run to fill a custom order for someone AFTER installing the modified Cuscos in my car...
Old 06-15-2007, 11:01 AM   #19 (permalink)
SE-R GREEK
Scott, it was about time you got an itchy-bitchy-tiny more active. Long time man...
Old 06-15-2007, 01:10 PM   #20 (permalink)
Tired!
coach's Avatar
I think it was the pillowball mount along with the camber that people were intersted in. I have been looking for rear plates for my Hpyerco Gen2/AGX setup on the daily.
Brent
