Old 12-10-2005, 10:20 AM   #21 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Originally Posted by octotat
i was thinking more on the lines of this
http://static.summitracing.com/globa.../csi-928_w.jpg
not our application though - i think it's for a 300zx???
it would be a tight fit, but i think it could work............... if i could get someone to cut that plate
-chuck
http://store.summitracing.com/partde...a utoview=sku
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 12-10-2005, 10:21 AM   #22 (permalink)
SENTRASER's Avatar
P.S...not sure if that would fit between the engine and the right frame rail.
Old 01-08-2006, 02:09 AM   #23 (permalink)
SE-R Geek / Nissan Tech
I'd be willing to notch the frame for that.
if you would need old p/s pumps i have 2
OH YEAH ONE MORE IDEA....what about a bracket that would slide the alternator back a little to line the pulley up with the water pump?
then we could all have our crank pulleys machined down to the inner pulley!!!
92 SE-R Autocrosser.... too much to list
Old 01-09-2006, 12:35 PM   #24 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
I guess I should get on that plate sometime soon then...
Old 01-09-2006, 02:44 PM   #25 (permalink)
SENTRASER's Avatar
You mean, step up to the plate sometime soon, Pat?
Old 09-15-2006, 01:50 PM   #26 (permalink)
well 9 months later....heres the idea....need to do some cleaning up on the power steering elimnation kit...and find the right belt, simple tighten to tension adjustment, elminates the entire power steering assembly and bracket, plus the cast iron piece everything attaches to...figure 15lbs removed, and this unit with the pully weighs in at 2-3 lbs
Old 09-15-2006, 08:49 PM   #27 (permalink)
SENTRASER's Avatar
So when does this piece go into production?
Old 09-15-2006, 09:15 PM   #28 (permalink)
Well, im cutting a couple more with the material I have...dont know how much of a production run ill do, possibly a couple at a time...right now im cleaning up the program and reducing the weight of it even more. Right now, its tiping the scale at 1.75 lbs Still need to work on that bracket support piece too. Expect a final version of this by next week or sooner.
Old 09-15-2006, 10:56 PM   #29 (permalink)
i just got a call from someone asking for a kit like this. how much would you be selling this kit for?
n2nismo is offline   Reply With Quote
Old 09-16-2006, 12:50 AM   #30 (permalink)
Registered User
laisla's Avatar
will this also fit the gti-r.
laisla is offline   Reply With Quote
Old 09-16-2006, 03:50 AM   #31 (permalink)
banned
Trader Rating: 23 (96%)
wow nice work pat any idea on price
G-Unit91 is offline   Reply With Quote
Old 09-18-2006, 11:11 AM   #32 (permalink)
Since this isnt head specific, it *should* work on all SR20 blocks (FWD) Thats assuming they all have that bracket on the lower part of the motor where the PS pump rotates.
Price is gonna be in the $175-$200 range.
Old 09-18-2006, 03:45 PM   #33 (permalink)
Registered User
laisla's Avatar
when will they be for sale
Old 09-18-2006, 07:28 PM   #34 (permalink)
a week maybe...once i get the rest of this nailed down, ill make an official thread about it.
Old 09-22-2006, 02:34 PM   #35 (permalink)
Fabricator
Ok - so of what I can figure this is only eliminating the PS pump - what about the whole rack and pinion system - Is the plan to keep using it, just w/o the assistance of PS??
I want to completely eliminate the rack and pinion and go to an "old skool" steering gearbox. I know the steering shaft that comes out of the firewall is gonna have a spline end - which I don't have the means to cut, but that's not important - steering gearboxes are geared to give some mechanical advantage correct?? Does anyone know if there is such a steering gearbox that is already in production (by nissan) for an older car or something that will accept the male spline of the steering wheel shaft??
Much weight could be eliminated by throwing the rack and pinion away for a steering gear box, and also mine is blown and I don't wanna buy a new one LOL
If anyone knows - let me know...
Project Zr34
*coming soon*
Project Reaper
(AWD B14)
zero1dhd is offline   Reply With Quote
Old 09-22-2006, 03:38 PM   #36 (permalink)
you can look for a B13 manual rack....dont know if it bolts up to a B14 but im sure it could be made to fit.
Old 09-22-2006, 03:44 PM   #37 (permalink)
Fabricator
sweet - thanks - and of course any thing can be made to fit. The only way to go is with a manual rack thou?? Nissan never made just a simple steering gearbox??
Old 09-22-2006, 04:37 PM   #38 (permalink)
Slow and Steady
Awesome -- count me in for one as well.
Chicane is offline   Reply With Quote
Old 09-22-2006, 04:55 PM   #39 (permalink)
Now accepting donations!!
El Gabito's Avatar
a manual rack is a simple steering gearbox...
My real name is Kyle
El Gabito is offline   Reply With Quote
Old 09-22-2006, 05:04 PM   #40 (permalink)
Fabricator
Thanks - I'm not very familiar with rack and pinion systems - I figured when he said a manual rack he was referring to a rack and pinion w/o PS - which is what I don't want. If there is a gearbox out there - can you direct me a little. I tried searching for a B13 system like Yahnoza mentioned, but all I came up w/ was the rack and pinion w/ PS.
