Old 09-22-2006, 06:23 PM   #41 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
www.car-part.com , also the stock SE-R actually has LESS turns lock to lock than the manual B13 rack. You could also look at a B12 possibly?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 09-28-2006, 02:52 PM   #42 (permalink)
AG>SR
party over there
AG>SR's Avatar
Trader Rating: 40 (100%)
.....would definitely buy on if it fit the 54C block.....
random music
more random music
and beeee veeeeerrrry
AG>SR is offline   Reply With Quote
Old 09-28-2006, 03:26 PM   #43 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
Well if your block has this bracket...it will work. This isnt high/low/vvl/rr dependant since it bolts to the block and I do believe all SR blocks have this bracket in one form or another.
Some more progression photos
Back side
Wouldnt you know, it even works with the Custom Steel Oil Relocation block
I still have to make one more part to this and thats the support bracket for the intake manifold...a small chunck of aluminum should suffice. The whole unit only weighs 1.75 lbs too, thats a nice weight savings.
Old 09-28-2006, 04:44 PM   #44 (permalink)
AG>SR
party over there
AG>SR's Avatar
.......nicenicenice....put me down for one.....
Old 10-02-2006, 11:00 AM   #45 (permalink)
Chicane
Slow and Steady
Question -- my SE-R cup car began life as a 1991 B13 Sentra E. So it has the Sentra E (no-P/S) steering rack. However, it has a full SE-R driveline swap and my SR20 is currently turning a P/S pump that is not pumping anything.
Now -- I just wanted to make sure that your elimination kit would not present any problems for such a setup (I don't see why it would -- just checking since my setup is a little out of the ordinary).
Chicane is offline   Reply With Quote
Old 10-02-2006, 11:13 AM   #46 (permalink)
Yahnozha
Actually this is the whole reason i really got on this. Ive got the same setup, B13 with the manual rack that im swapping a 2.0 into. I didnt want to run a PS pump with no fluid because it will eventually burn up and seize, and wanted a nice easy way to tension the WP belt. So yeah, to answer your question, it will work on your setup no problem.
edit: im almost done with the little bracket and just need to find the right size belt now...
Old 10-04-2006, 11:37 PM   #47 (permalink)
djtwinky
Blown Up SER
very interested...dont need power steering to go down the quarter...i think itd make my car feel more "real"
djtwinky is offline   Reply With Quote
Old 10-09-2006, 05:38 AM   #48 (permalink)
Chicane
Slow and Steady
Yeah -- right now my PS pump has fluid lubricating everything -- but it just circulates back onto itself (wasting space and weight). Your kit will help nicely.
Old 10-09-2006, 12:54 PM   #49 (permalink)
SENTRASER
SENTRASER's Avatar
Ship one to me, I'll find a belt the right size.
Old 10-10-2006, 11:04 PM   #50 (permalink)
TurboTank
slamed150
Trader Rating: 45 (100%)
f that ill buy one from yea and get belt numbers
TurboTank is offline   Reply With Quote
Old 10-11-2006, 12:13 PM   #51 (permalink)
Yahnozha
Okay guys, im going to be finishing up the last part of this today...Ill have 3 ready to go by the end of the day. I dont have the time to figure out the belt size for this but for those of you that want to buy this youll have to get the belt on your own.
Im asking $175 for the first three units shipped, youll have to find the right belt. Sorry but my time is limited and these are the only ones ill have until late november....so that being said, its going to be a first paid first served...the first 3 that get payment to me will get these. Ill be able to ship tomorrow.
paypal $175 to bossman@customsteel.com
Old 10-11-2006, 07:48 PM   #52 (permalink)
TurboTank
slamed150
paid
Old 10-11-2006, 07:58 PM   #53 (permalink)
Yahnozha
one left guys, two have been paid for.
Old 10-13-2006, 03:10 PM   #54 (permalink)
Yahnozha
slamed150: Yours in on the way...should get a notice from USPS with the deliver confirmatin number sent to your paypal email...
Still one left...
Old 10-13-2006, 05:11 PM   #55 (permalink)
kleensleeper
The NX crew.
I'll take the last unit if you still have it pat.
91 NX2K U13 DET....3071R powered
12.00 @ 122mph
Stock b13 tranny ftw.
Tuned by the KeepLabs crew.
kleensleeper is offline   Reply With Quote
Old 10-13-2006, 05:19 PM   #56 (permalink)
kleensleeper
The NX crew.
Paid...
Old 10-17-2006, 11:53 PM   #57 (permalink)
TurboTank
slamed150
install:
http://www.sr20forum.com/showthread.php?t=174397
Old 10-18-2006, 03:32 AM   #58 (permalink)
SENTRASER
SENTRASER's Avatar
Also....one idea, what about making a spacer to make it so you can run the alternator and the w/p off the same belt, just move the water pump pully out slightly, then the alternator would tension the belt. Just an idea, as I wouldn't use washers for that, because they're not precise enough, I would want a spacer and some longer bolts. Dont make me draw one of my pics though...hehehe...MS Paint FTW!
Old 10-18-2006, 11:10 AM   #59 (permalink)
Yahnozha
I honestly dont think you have enough room on some of the frames to do that...
Image blatently stolen from tank at IPS
Old 10-18-2006, 06:04 PM   #60 (permalink)
Jaketips42
Making the G breathe hard
Jaketips42's Avatar
Trader Rating:
