Old 01-08-2006, 02:15 AM   #1 (permalink)
BRE92SER
SE-R Geek / Nissan Tech
Request: Motor Mounts
How about a solid aluminum dogbone, along with aluminum inserts for the other 3?
I would say all solid mounts, but i dont want to go to the dentist THAT often....
92 SE-R Autocrosser.... too much to list
Old 01-09-2006, 12:38 PM   #2 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
If you have a spare dogbone, cutting a solid aluminium one shouldnt be too much of an issue...as for aluminium inserts for the others, you might as well make them all solid, or go with the prothanes
Hell, if you make them all solid, you can relocate the center hole lower in the opening and drop the center of gravity down a bit and ease the stress on the axles for lowered cars. Although, this wouldnt bode well for the oil pan
Old 01-09-2006, 10:18 PM   #3 (permalink)
BRE92SER
yeah then we'll have to get someone to make us baffled oil pans and skid plates...thats just too bad
Old 01-29-2006, 04:30 PM   #4 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Pat, you should make a dogbone mount that is for the U13's and W10/11's. Someone made one a while ago with just two ES shifter bushing housings welded together.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 01-30-2006, 12:34 PM   #5 (permalink)
Yahnozha
Ive seen the one your talking about, and i would still need dimensions and what not to cut it...Id make it billet aluminium instead of welded steel. Even then id still be guessing on the *correct* size.
Old 01-30-2006, 01:00 PM   #6 (permalink)
blackb13se-r
boost junkie!
jackson dimond did it on his disco install.
91 SENTRA se-r
dead SR20VE-T
"I stays breakin stuff"
For sale!
http://www.sr20forum.com/showthread.php?t=161787
check out www.ecdrift.com for you sideways guys!
blackb13se-r is offline   Reply With Quote
Old 01-30-2006, 01:07 PM   #7 (permalink)
Yahnozha
so whos gonna send me a dogbone with stock bushings in there so I can measure?
Old 01-30-2006, 01:42 PM   #8 (permalink)
wes
712 ways to be a dick!
Trader Rating: 23 (100%)
I think you mean thomes reynolds....
my site
Old 01-30-2006, 02:09 PM   #9 (permalink)
blackb13se-r
boost junkie!
my fault.
Old 01-30-2006, 11:35 PM   #10 (permalink)
BRE92SER
anybody have a spare...I dont even have 1 right now!
Old 01-31-2006, 12:17 AM   #11 (permalink)
SENTRASER
SENTRASER's Avatar
http://www.turbotime.us/ProductDetai...000-1117317766
Old 01-31-2006, 12:14 PM   #12 (permalink)
Yahnozha
yeah, ive seen that one too.....
