....I'll try to get it made locally to test the angles but........4-9 degree..
.......there has been some chatter and intrest/intent on a wedge/taper spacer to bolt between the stock manifold and a large turbo that would have to be ground or need the block ground to fit........
........if there were corresponding washers with the reverse angle to give the studs an unbiases load.......something like this should work right?
........any way, do you think this is something you would have time for in the next month or so??
..........thank you for all your efforts put into this camp.
.......__Jason
