and beeee veeeeerrrry
So what's the total for a rail with the o'rings for Seimens injectors shipped to 00602? Let me know so I can send you a money order. Please include your shipping address. Thanks.
Yes, this rail will work with the stock GTiR injectors, but heres what you have to do....
First off, FI clips that i provide wont work on GTiR injectors. Second, Ill change the port size to 11mm in the rail for the tops of the GTiR injectors (all the others are 14mm).
From there youll have to find some 10mm ID hose and cut to length to use as a spacer between the top of the injector and the fuel rail to hold the injectors in place firmly. Basically, just long enough for it to get *squished*. Otherwise, the injector will just float there and could move enough to lose the seal on top or bottom oring.
