Old 07-21-2006, 05:08 PM   #1 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
CS - Oil Relocation Block Installed
Well here you go guys, some photos of an installed setup. I dont know the specifics on hose, hose length, cooler or remote filter mount...there are some ideas in this thread about the block. The fittings coming out of this block were both straight.
http://www.sr20forum.com/custom-steel/97944-cs-oil-relocation-block.html
Cooler and filter options are on the second page, but suggest you find whats best for your setup....oh, and this is on Derriks cup car
Old 07-21-2006, 05:30 PM   #2 (permalink)
Enemy of the stupid
This thing fit the VE's? or just the DE's?
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 07-21-2006, 05:46 PM   #3 (permalink)
Im not 100% sure on that, it should since its basically a DE block with a VE head on there. if you can get me a photo of the oil filter block, ill be able to tell you.
Old 07-21-2006, 06:05 PM   #4 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Both the DE and VE has the same holes for the oil filter. I'm using a VE filter bracket on a '91 high port. 0 problems.
1991 Sentra SE-R
The community is here.
Old 07-21-2006, 06:11 PM   #5 (permalink)
well, there you have it, it will fit the VE
Old 07-21-2006, 10:22 PM   #6 (permalink)
Technician @ Toyota
scortch99th's Avatar
Bump for high quality , good price, great seller, and SR20 parts
nice job p@t
-freddy
91 classic SE-R
94 classic LE
91 240sx(rps13)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 07-24-2006, 06:51 PM   #7 (permalink)
NASA #92 PTD
As seen above, my setup consists of P@s' oil relocation block, which removes the stock oil filter 'tower', (with a smooth 90 deg. and smooth 45 deg. fittings connected to the straight -10 o-ring fittings out of P@s' block), the Nissport oil pressure sensor adapter, a Moroso remote oil filter mount (takes the standard big asss chevy truck filter), -10 fittings (except 1/2 npt in-out of remote oil filter), and a 16 row Earls Temp-A-Cure oil cooler. No thermostat.
Oil lines lengths are going to vary depending on your filter/cooler mounting locations.
Derrick Malcolm
Enterprise Automation/Malcolm-Racing
#92 - Nissan Sentra SE-R
NASA Southern California - PTD
www.malcolm-racing.com
derrick is offline   Reply With Quote
