Old 02-08-2007, 10:53 PM   #41 (permalink)
Beakmoney
debt or det?
Originally Posted by Yahnozha View Post
the rotor for this kit is 11.4", larger than the ones your talking about. Now the P10 piston is larger than the B13 stock one, how much larger, im not positive, but its definately an upgrade all the way around.
right, however which year maxima were you testing the caliper from? because as i said, 89-91/92-94 are different..and IIRC, 95-01 are different also.
02 WRX wagon 5spd. reflash and other stuff..its still slow.
Beakmoney is offline   Reply With Quote
Old 02-08-2007, 11:10 PM   #42 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
Ive never tested the maxima caliper, but piston wise, it should be the same as the P10. But you cant use the maxima caliper with this setup, the torque member is different.
Old 02-09-2007, 02:08 AM   #43 (permalink)
Beakmoney
debt or det?
alright, apparently i misunderstood you.
OT: are you on AIM ever? i've got a few things to ask you about, possible developments for the rear suspension
Old 03-27-2007, 06:59 PM   #44 (permalink)
SE-R 173
BOOSTED SE-R
So do the b14 wheels work with these or not?
SE-R 173 is offline   Reply With Quote
Old 03-29-2007, 11:16 PM   #45 (permalink)
SE-R 173
BOOSTED SE-R
anyone?
Old 03-30-2007, 08:30 AM   #46 (permalink)
Fosters I am a moderator
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
I would assume so. I had 15" Rota C8's and they had plenty of room. The Rota's aren't like some of the Team Dynamics wheels that have more clearance room.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 04-02-2007, 04:58 PM   #47 (permalink)
Yahnozha
this will clear a stock 15" P11 rim on a P10, not that it helps you any, but its a tight fit, i highly doubt it will fit under 14" rims.
Old 04-02-2007, 06:34 PM   #48 (permalink)
Andreas Miko
Jah Rastafari
Trader Rating: 53 (100%)
I did not have time to read this thread but I have a friend with a P10. Am I correct by saying that to put this on a P10 all we will need is
1. Your brackets
2. The rotors
This means these 11.3 inch rotors come with the 4 x 114 bolt pattern so they bolt right up and your caliper brackets and then the stock P10 calipers. We dont even need to bleed the brakes.
So is this all we need to do to put this on my friends P10
Old 04-02-2007, 09:03 PM   #49 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
CS sells a bracket to mount P10 calipers and you can use the larger NX rear rotor or re-drilled P10 rotors.
Brent
Old 04-02-2007, 09:18 PM   #50 (permalink)
markbuts3
Primera Nut
1. Your brackets
2. The rotors
All you need is the brackets (dogbones), bolts and rotors (yes they are 4x114.3) for a P10.
http://www.g20.net/forum/showthread.php?t=50651
http://www.g20.net/forum/showthread.php?t=51684
Kyle just fitted them too.
http://www.g20.net/forum/showpost.ph...2&postcount=32
My Cardomain page and My website check them out
markbuts3 is offline   Reply With Quote
Old 04-02-2007, 09:32 PM   #51 (permalink)
Andreas Miko
Jah Rastafari
Brent
You are way off on this question.
I have had laege brakes on my SER from god knows when
This has nothing to do with SER this has to do with G20s.
I answered my own question anyway
Old 04-03-2007, 11:35 AM   #52 (permalink)
Yahnozha
1. Your brackets
2. The rotors
correctomundo, if you get the brackets, ill even tell you what rotor to buy. Its a direct swap on the P10, you just need to grind a tad off the passangerside torque member for clearance. Other than that, its a bolt on affair.
Old 04-03-2007, 03:24 PM   #53 (permalink)
Andreas Miko
Jah Rastafari
I know what rotor it is already.
Old 04-09-2007, 05:04 PM   #54 (permalink)
Andreas Miko
Jah Rastafari
Hey give me a Pm I want to get 2 sets of brackets
Old 04-10-2007, 01:06 AM   #55 (permalink)
Beakmoney
debt or det?
anyone know if these will fit under stock P10 wheels?
need to know before i buy so i can decide whether or not to first of all do it, and second of all what wheels i should pick up for the winter (i have P11 wheels for the summer) if i decide to.
Old 04-10-2007, 01:11 AM   #56 (permalink)
markbuts3
Primera Nut
http://www.g20.net/forum/showpost.ph...02&postcount=6
http://www.g20.net/forum/showpost.ph...35&postcount=8
Old 04-10-2007, 07:42 PM   #57 (permalink)
Beakmoney
debt or det?
Mark, you are the man!
Old 04-11-2007, 08:39 AM   #58 (permalink)
Andreas Miko
Jah Rastafari
OK I am trying to get 2 sets of the brackts one for a P10 and one for a B13.
Please give me a call or PM me so we can get this onthe way.
Old 04-15-2007, 09:45 AM   #59 (permalink)
Andreas Miko
Jah Rastafari
No love on the brackets. No Call, no Pm
Old 04-15-2007, 11:11 AM   #60 (permalink)
paNX2K&SE-R
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 65 (100%)
Pat's been *REALLY* hard to get in touch with Dre, he has a ton of stuff on his plate right now from what I understand. People on G20.net said they have been getting stuff that they ordered and paypal'd for though.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
