Old 12-06-2006, 09:32 PM   #1 (permalink)
Jaketips42
Making the G breathe hard
Jaketips42's Avatar
Another idea
I was browsing JWT's site and found this. http://www.jimwolftechnology.com/***...asp?PartID=449
If you were to make one half as thick as to hold 1/2 qt+, that would great.
**Snap On box on ebay**
Old 12-06-2006, 09:44 PM   #2 (permalink)
G-Unit91
banned
Trader Rating: 23 (96%)
good idea
G-Unit91 is offline   Reply With Quote
Old 12-06-2006, 09:48 PM   #3 (permalink)
robchaos19
Robusto
Trader Rating: 78 (100%)
You'd have to figure out what to do with the oil pickup on the SR20 though to add 1/2" length to it. The setup is a little different then the vq35 ours has that little bracket that goes to the crank cage that would have to be lengthened.
Would be nice though if they made one for our engine.
robchaos19 is offline   Reply With Quote
Old 12-07-2006, 11:34 AM   #4 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
do you really want your oil pan sitting that dangerously low to the ground? I know i wouldnt feel to comfortable about it....it sits low enough as it is....
but if there is enough demand, and you all understand the risks of installing one of these, I would give it a shot. Dont expect it to be too cheap, id probably fab up some sort of steel guard to minimize the chance of punching a big hole in the oil pan...
seriously, take a look at your pan now and get back with me.
Old 12-09-2006, 08:56 AM   #5 (permalink)
Jaketips42
Jaketips42's Avatar
The one on the site is thick. If you made that 1/2 as thick, it shouldn't be too bad. Out pan is low though, you're right.
Old 12-09-2006, 07:26 PM   #6 (permalink)
codyace
I ride the deer!
codyace's Avatar
I don't like the idea...
without really checking, here is some simple math I did
Figure that the lower pan is what, around 7" square? So if you want to make a 1/2 inch spacer, you're looking at the spacer adding an extra volume of what, 24.5 cubic inches extra. Converting 24.5 cubic inches to gallons, and you get .10 gallons, which when converted to quarts gets you .33 quarts
To me, lowering that pan to get an extra .33 of a quart (give or take) is silly. You'd be better off enlarging the hole slightly on the pickup than anything...
Cody Ace
97 240 - SR - 400whp/330ft lbs
365th EN - OIF 3+4
Turbo Altima R.I.P.
Click Links for Gallery
codyace is offline   Reply With Quote
Old 12-09-2006, 11:35 PM   #7 (permalink)
TOOQIKK
slave to the grind
TOOQIKK's Avatar
Trader Rating: 28 (100%)
what about and oil pan that is wider not lower....ill try and find apic of one off of a v8 i saw the added to the sides to widen it and add capacity but no hurt ground clearance....
1991 xe....dead(boneyard)
1994 e.....dead(parted out)
2007 hyundai accent 3dr auto charcoal grey... tint, new shoes,custom SRI, HID(4200k bixenons), ICE. custom hi intensity blue LEDS entire dash, 2.25" custom magnaflow exhuast
Old 12-10-2006, 01:33 AM   #8 (permalink)
himbo
Nis-ho
i would love it if you made something to protect our pans...
Still aiming for 350whp...
himbo is offline   Reply With Quote
Old 12-10-2006, 02:08 AM   #9 (permalink)
codyace
I ride the deer!
codyace's Avatar
Living in NJ would involve a skid plate of an Nismo Off Road Titan hehe....I do think that North NJ has the worlds largest freakin pot holes...
Old 12-10-2006, 02:55 PM   #10 (permalink)
Yahnozha
seriously, if you want to add in a bunch more oil, get one of these....
http://www.sr20forum.com/showthread.php?t=97944
then plumb in a remote oil filter and oil cooler.
With a dual filter setup, youll easily introduce a qt or more into the system and still have the oil pan clearance you need.
