Old 01-31-2007, 08:43 PM   #1 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
Custom pieces...
Hey Pat. I was wondering if you could make something for me. I am currently on a quest to fit NX front seat belts into my four door sentra I just purchased.
The four door frame only has two adjacent 10mm head 6mm shaft bolt holes in the B pillar that could be used for mounting this sucker. Instead of switching the NX belt mounting bolt from a 14mm head 10mm shaft bolt to a 10mm head 6mm shaft I want to utilize both 6mm bolt holes.
Anyway, here is a picture showing you more or less what I would be looking for.
This is just to show you basically that you would need to drill 3 holes and tap one, and give the tapped one enough threads to be strong enough for a seat belt.
Obviously I would provide you with *EXACT* dimensions if you said this is something you could do.
Thanks,
Luke
Old 02-08-2007, 05:05 PM   #2 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
hum, im pretty hesitant on doing stuff that is safety related...as long as you can provide me with dimensions and your material specs ill give it a shot...wont be until mid march ***.
Old 03-15-2007, 11:52 AM   #3 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
Pat,
I pulled out my automatic seat belts a little while back, and I found that those two 10mm holes are the only thing holding the seat belt to the frame. Therefor, if we did this, it should be 100% in the safety department.
It's mid march, so this is me asking if you have any time if I send you exact measurements.
Old 03-20-2007, 02:18 PM   #4 (permalink)
Yahnozha
well sh*t, give me another week and if you can get specific dimensions, and material that you want me to make it out of, ill give it a shot.
Old 03-20-2007, 02:35 PM   #5 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
I am not educated in the materials department, so here is the part where I ask for your suggestion. I would want a metal that isn't very brittle in any temperature range... say -20* f to 120* f... but aside from that I could care less. Cheaper is better.
Old 03-20-2007, 02:38 PM   #6 (permalink)
Yahnozha
id say get me some exact measurments, and ill see what i can do.
Old 03-20-2007, 02:45 PM   #7 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
will do
