Old 03-11-2007, 07:26 PM   #1 (permalink)
NismoNephi92
i need a top feed fuel rail
i was referred here to have a top mount fuel rail made for a bluebird motor in a 92 g20. how much would that run? and would i be able to use any top feed injectors with it?
NismoNephi92 is offline   Reply With Quote
Old 03-20-2007, 02:25 PM   #2 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
im guessing a high port, and yes, almost any top feed injector will work, but the pintle has to be 14mm in diameter, there are some that have 11mm pintles and i can custom make a rail for that tool.
