Old 06-26-2006, 07:53 PM   #61 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
Not sure what the question is at this point. If your wanting an aftermarket sender, if its small enough, you can drill and tap it yourself. Ill just be doing the stock pressure gage port. (1/8 bspt for those that dont know)
Old 06-26-2006, 08:41 PM   #62 (permalink)
Zexel
The Boost Bear..Rawr!
Zexel's Avatar
Trader Rating: 27 (97%)
Right. I just wanted to verify that putting the 1/8" BSPT was the only port you planned on drilling and tapping.
Zexel is online now   Reply With Quote
Old 06-26-2006, 09:33 PM   #63 (permalink)
Yahnozha
yeah, thats the plan at this point.
If something is needed to run an aftermarket sender inline, im sure i could build something along this line. But that would just add in more hose and hose ends.
http://www.pegasusautoracing.com/pro...p?Product=1227
Old 07-03-2006, 04:22 PM   #64 (permalink)
focus
For give my ignorance here.
Do you have to move the sender to the relocation block?
focus is offline   Reply With Quote
Old 07-05-2006, 02:33 PM   #65 (permalink)
Yahnozha
You are completly removing the stock spout from the block to install this. Therefore, the oil sender will be removed and put into the new relocation block. Does that make sense, or shoul i put up pretty pictures?
Old 07-24-2006, 09:22 PM   #66 (permalink)
Lunar240z
'71 240z, a REAL classic
what does the back look like if you dont mind me asking... just curious.
Lunar240z is offline   Reply With Quote
Old 07-25-2006, 10:47 AM   #67 (permalink)
Yahnozha
Its got two ports cut for the stock o-rings to fit in and seal. I also provide the two o-rings youll need.
Old 06-28-2007, 01:43 PM   #68 (permalink)
RedDragun
The DET is in!
Trader Rating: 17 (100%)
Updates on these? I wanna run a big ass chevy small block filter. I found one that filters down to .45 micron.
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 07-21-2007, 04:48 AM   #69 (permalink)
Low612
SE-R Turbo Slut
Trader Rating: 29 (100%)
What is the possibility of having them made for the gtir motor?
Larry Low
LAMO IMPORTS
k6 GSXR 750
01 Ducati 996
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline   Reply With Quote
Old 10-07-2007, 05:46 PM   #70 (permalink)
Matty Moto
Auto Pilot
Matty Moto's Avatar
Trader Rating: 13 (93%)
Pat,
Do you have these available?
I am sending you Paypal. Please let me know.
Matty Moto
92' SE-R "The Red Barron"
92' SE Grocery Get'r
Matty Moto is offline   Reply With Quote
Old 10-11-2007, 06:30 PM   #71 (permalink)
Turbo91SER
SE-R with passing power
Can i ask what filter that is?
'91 SE-R FMAX DET - '74 260Z - '05 G35C - '94 E Daily Driver
Turbo91SER is offline   Reply With Quote
Old 10-24-2007, 04:59 PM   #72 (permalink)
Yahnozha
well I just got done doing a run of 7 of these, i need to order gaskets and fittings for some of them.
I dont know what the difference is on the GTiR block, photos would help.
Old 01-26-2008, 10:24 AM   #73 (permalink)
nismo_star
Ego Destroyer On Board
nismo_star's Avatar
Trader Rating: 25 (100%)
Anymore left ? I need 2 ?
RPM NYC Welder, Diagnostics, Fabrication, Wiring.
Nissan Performance Division.
Queens Village, NY 11428
J.E.T Speed Lab
Chasis Bracing, Brakes, Safety Products
Bronx, NY 10454
A33 SE VQ35DE-K
B13 SER SR23DET
R50 LE VQ35DE
S50 Sport VQ35DE
SHIFT_Art of Power.
nismo_star is offline   Reply With Quote
Old 02-02-2008, 12:44 PM   #74 (permalink)
viscos2000
SE-R enthusiast
I would like 1 and would like to discuss using this with an accusump system.
1993 Red SE-R: Progress coilovers (Gardner spec)rear sway,UR pulleys,AEM custom CAI,HS G6(3in),3in exhaust,S3 cams,PC680,ES kit,Prothane MMs,GC Camber plates,Shig rears,NX rad,CS H2O adapt,AD22s,Crown Lines,Carbotech/Axxis pads,FSTB,Progress LCA brace, Black Rota C8s on Azenis,IOport camera mount&seat brace,Technosquare cage,Techtom, Sparco seat, g-force5pts
viscos2000 is offline   Reply With Quote
Old 04-03-2008, 07:47 AM   #75 (permalink)
nismo_star
nismo_star's Avatar
accusump works beautiful, just a pain mounting inside the car, running a bulkhead -8an tee, but beautiful system.
