Old 12-03-2004, 05:07 PM   #1 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
CS - Oil Relocation Block
Okay guys, this is the latest development coming out of Custom Steel for the SR20. Its an oil relocation block. This bolts onto the back of the block replacing the oil filter spout. That being said, you also have to find yourself a remote oil filter bracket of sorts, and associated tubing to go with this. This is shown on a high port engine.
edit update
Here are some photos of what is actually in the kit that im selling
blue aluminium fitting shown for illustration purposes
The red dot illustrates where a port for oil pressure sender would go, either the stock 1/8 bspt or a 1/8 NPT for aftermarket guages.
Edit, the red dot is no longer the place where the 1/8 bspt port will be, it will look like this.
Comes with the block, both oil seals, and two -10 AN oring boss fittings. Price is $175 w/o fittings, $185 with straight fittings, and $200 with 90* fittings.
Old 12-04-2004, 06:15 PM   #2 (permalink)
scortch99th
Technician @ Toyota
scortch99th's Avatar
i love your products.(i got the water spacers)
well i want to know when they are done, or are they?
Can you also take pics of the hardware and how we will recieve it.
Is it possible to get some fittings from you?
What is your next project if you have one comming im interested in just about any piece you'd make. quality and fitment are hard to find for our sr20s. thanks
91 classic SE-R
94 classic LE
91 240sx(rps13)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 12-04-2004, 08:03 PM   #3 (permalink)
HkSBlueBird4u
Travieso Racing
that sh*t clears powersteerin pump?>
Danny GDM (HKS)
1993 PRiMERA GT
Old 12-05-2004, 01:39 AM   #4 (permalink)
SR20 Inside
FWD PWNAGE COMING SOON
Pat that is some sick sh*t. You always make the dope stuff !
SR20 Inside is offline   Reply With Quote
Old 12-05-2004, 11:09 AM   #5 (permalink)
Justin
Its Slow
Looks like it should clear the PS pump. I'll wait for Pat to have the final say though. As long as it does, I'll take one. I also want one each of your water temp adaptors, Pat. Please pm me or let me know on here how much all 3 shipped would be. Thanks!
- Justin
http://www.imagestation.com/picture/...e/f9a9e41f.jpg
http://i149.photobucket.com/albums/s...rley05/b14.jpg
96 SE-R White, BIG turbo
96 SE-R Black, stock mostly
05 Dodge Ram 1500 4 door 4x4, Tow vehicle
Justin is offline   Reply With Quote
Old 12-06-2004, 11:29 AM   #6 (permalink)
Yahnozha
The top photo with one more zinc plated fitting is all youll get. So thats the block plus two -10AN fittings that screw into the block, and two oil seals that will fit on the back side of the block up against the motor.
fo-shizzle!
Thanks, and Im just getting warmed up!
Yep, this clears the water pump, and Ill PM you on the three items...Ill have to get some specs from you on the H20 Adapters....
Old 12-09-2004, 09:56 PM   #7 (permalink)
Justin
Its Slow
Cool! The sooner the better!
Old 12-09-2004, 10:06 PM   #8 (permalink)
BerBer5985
Motorless SE-R
ummm...what exactly is the point of this....forgive me being ignorant, but what is it for?
BerBer5985 is offline   Reply With Quote
Old 12-09-2004, 11:30 PM   #9 (permalink)
Will
oh so LAZY
go do your own oil change, and then you will understand.
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 12-10-2004, 09:04 AM   #10 (permalink)
BerBer5985
Motorless SE-R
I've done it.....it's a pain in the ass......but where do you relocate the oil filter to? This is a pretty neat little thing.
Old 12-10-2004, 09:39 AM   #11 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 41 (100%)
What you can do is run oil lines out the neck and mount a filter about anywhere. SOme people run the lines along the passenger side to a filter mounted up front by the radiator. Not sure where mine will be, it would be nice to have it down low in the back, slide under with a dolly and pull the filter while you undo the drain plug on the oil pan! THat would be nice!
Brent
Old 12-10-2004, 10:07 AM   #12 (permalink)
91 Talon
Who's your daddy?
91 Talon's Avatar
Trader Rating: 16 (100%)
I would try and mount mine like a RX7. Higher and still in the upright position. perfect for draining.
'99 Sentra SE-L (wifes)
'92 SE-R white - Auto-X beast/DD
TechWarrior - http://world2.techwarrior.co.uk/?ac=vid&vid=45106639
91 Talon is offline   Reply With Quote
Old 12-10-2004, 12:39 PM   #13 (permalink)
Yahnozha
You can mount the oil filter where ever you want to. Ive seen a couple of setups where the filter was mounted near the front underneath the ABS pump on the frame there.
Yeah, the next phase of this is gonna be a new steering rack clamp that has a flat face to bolt stuff too...this might work well for mouting a remote filter kit there, plus it will make the lines really short.
Old 11-03-2005, 03:17 AM   #14 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Exscuse my late post,but how much are these things? And Is it possible to get them with 1/8 BSPT for the stock dummmmmmmmmy light? If not, I have an 1/8 BSPT tap.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Old 11-03-2005, 11:34 AM   #15 (permalink)
SR20 Inside
Hey Pat does this work with the oil distribution block you sell?
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Now rallying around SL,UT.. watch out
www.UtahNissans.com
www.RallySportDirect.com
Old 11-03-2005, 02:12 PM   #16 (permalink)
Yahnozha
Im asking about $185 for this unit with the male fittings coming out of it. I can probably do the 1/8 bspt on there, I just gotta check and see if there are any clearance issues with it.
Nope, this unit is strictly for oil filter/cooler relocation, its got huge 5/8" lines (-10an) coming out of it for semi long runs of hose up to the front of the engine.
Old 11-04-2005, 07:28 AM   #17 (permalink)
grizz00
shift!_now?
Trader Rating: 15 (94%)
Cs Does It Again!!! Good Work.
ALL FAST CARS GO TO HEAVEN!
GAINING RESPECT ONE PSI @A TIME!
my stuff for sale
'91 SE-R.... SR?DE-t-----rOAd & TrACk
JUN'S GARAGE...We call this Non-Weak Sauce Racing
grizz00 is offline   Reply With Quote
Old 11-07-2005, 09:29 AM   #18 (permalink)
superdave013
That looks really nice. You should make a nice billet remote filter mount too. That way you could sell the complete kit with the lines and everything.
Glad to hear you like our hose ends.
Dave @ Sweet Performance
superdave013 is offline   Reply With Quote
Old 11-07-2005, 11:08 AM   #19 (
