Quickest Turbo 1/4 Mile Times - The "Old" List - SR20 Forum
Go Back   SR20 Forum > Motorsports > Drag Racing
Closed Thread
Old 01-30-2002, 04:20 PM   #1 (permalink)
9-second club
Ghettomax1- 1.60 60', 9.83 @ 145.66 (1993 SE-R) XTICAEPVMBOUF^LGSKNRWQ
10-second club
Anoesis - 1.669 60', 10.221 @ 140.12 MPH (92 Nissan Silvia PS13, Black) XJTIHCZAEPVMUF^LGSDRWQ
SER2FAST - 1.677 60', 10.34 @ 134 mph (1995 Nissan 200SX SE) XTICAEVMBOU^LGSKNRW
11-second club
insaneser 1.826 60' 11.78@120.10mph (1996 200SX black) XCEPVMOU^SKR
12-second club
sentramental - 1.815 60', 12.001@ 121.56 MPH (1991 SE-R, White) XTIHCAEPVMBOU^LGMSDR
Big Boost - 1.870 60', 12.297@110mph (1991 SE-R, Vail white) XTIHCAEMBOUF^KR
PDXS2000 - 2.19 60', 12.31 @117.8mph (1991 SE-R, White) XCVMU^LSKR
MarkSR20 - 1.84 60ft, 12.49@115.13mph, ICAEVU^S (1997 200sx SE-R, Blue)
HotshtSR20 - 2.021 60', 12.620@117.32 (White 98 200SX SE-R) SEXI^HACKRMVPQ
TUNED200 - 2.033 60', 12.73@109.74, JIHCAVMUKR^ (1996 200SX SE-R)
Skiddusmarkus - 1.89 60', 12.79@106.00mph (GTiR) IAEMU^S
SERprise In WV - 1.92 60', 12.80 @ 110.3mph ('93 SE-R, black) I CAME ^UK
myprojectb13 - 2.145 60', 12.883 @ 113.13 (1991 SE-R, Black) ICAMU^SW
SENTRAMAN- 1.844 60', 12.93@106.00(91 Sentra Se-r) JICAEU^KS
SeattleSE R - 1.946 60ft, 12.973 @ 109.92mph (97 SE-R, Cloud White), JICAEPVOUF^SKW
13-second club
NXRDET, 2.191, 13.02@185kph (1994 NX-R Maroon) JIZAEU^
Sr20ser1997 - 2.145 60', 13.177@105.38 MPH (1997 200sx, White) D^UOYECIA
NismoB13SE-R - 2.17 60', 13.18@108.21 mph (1991 SE-R, White), JICAEOU^SD
dougnosser - 2.688 60', 13.58@109.63mph. (1998 200SX-SE-R) JICAEPVOU^SD
97SE-R C2- 2.221 60', 13.618 @ 102.79 MPH (1997 SE-R, Red) JIAEOU^
mser-2 - 1.929 60' 13.03 @ 105.5 (93 se-r black) xcaepvmu^k
PULSSSAR - 2.099 60' , 13.771 @ 100.11 mph (1995 Pulsar, Red), JEUS
djisnx2000 - 2.337 60' , 13.740 @ 105.14mph, (1992 NX2000, black) JIEOU^
NX_DET - 2.226 60' , 13.792 @ 102.35mph, (1993 NX2000, black) JCAEOU^
Doug_O - 2.250 60', 13.854 @ 102.63 MPH (1993 SE-R, Red) JICAEOUS
turbo b13 se-r - 2.43 60', 13.86@103mph (92 SE-R, gray) JAEV
Soopastank - 2.3 60', 13.8 @ 104 MPH (96 and 200sx, White) Mods XICAEYOU^
Mods legend
X=Kit (FMAX, Hotshot, etc)
J=J-spec DET swap
T=Upgraded turbo (over "spec" DET/kit turbo)
I=Upgraded intercooler (over "spec" DET/kit IC)
H=Exhaust manifold
C=ECU upgrade
Z=Stand alone fuel management
A=Air intake (CAI, POP, K&N, etc)
E=Exhaust
P=Underdrive pullies
V=Cams
Y=Cam(s) from '91-'93 SR20 swapped in '94+ SR20
M=MAF
B=Throttle body
O=Short shifter
U=Clutch
F=Flywheel
^=Motor mounts
L=Lower end work (pistons, etc)
G=Head work (porting, etc)
S=Suspension
D=Drag radial or other DOT-legal "sticky" tire
K=Slicks
N=Nawwwwsssss
R=Race fuel
W=Weight reduction (other than just spare, jack and floormats)
Q=Quaife or other aftermarket differential
>=Not equipped with a viscous LSD
Some of you turbo guys can help me if there's something significant that should be included in the mods legend -- I don't know much about turbos.
Wanna get on the list? Here's all you have to do:
Submit your info in the following format:
Screen Name - X.XXX 60', XX.XXX @ XXX.XX MPH (Year and Make, Color) Mods (see legend)
Example:
slowG20 - 1.666 60', 11.829 @ 124.56 MPH (1993 G20, Gold) XTIZMBOSK
If you can't fill in all the X's I will use a '9' for 60' and ET and a '0' for MPH.
If your data is not in the above format it will not get posted!
These updates and additions will happen weekly . . .
slowSER is offline
Old 01-30-2002, 10:37 PM   #2 (permalink)
Master of the 5th speed
NO times, but a question, what should i be able to run 1/4 with 93 se-r w/det, aftermarket wastegate/bov, act clutch, stock intercooler, crap tires, everything else stock
-=- 91 accord -=- stock(R.I.P.)
-=- 93 sentra -=- se-r, short shifter, es motor mounts
KikoSanchez182 is offline
Old 01-30-2002, 10:45 PM   #3 (permalink)
Bad Banana
At least mid to low 14s.
www.boostednx.nismo.org
Loe Lyf is offline
Old 02-01-2002, 10:09 PM   #4 (permalink)
12.50@112.26 Fmax st 2 kit, jwt s3 cams, UR pulleys, ACT 6puck. run done on slicks.
Shawn Nielsen
95 G20t
ShawnSE-R is offline
Old 02-23-2002, 02:18 AM   #5 (permalink)
Fmax Stg II B13
12.3 @ 117.8 91 se-r fmax stg 2, 46 trim, race fuel - 18psi, vg30dett pistons (9:1), S3 cams, ACT street/strip, no exhaust, full interior etc. 14x6 slicks, 2.1 60ft
Brian
00 s2000 | 04 R1 | 04 WRX wagon
sold: 91 SE-R Turbo 12.3 @ 118
PDX S2000 is offline
Old 02-23-2002, 04:44 AM   #6 (permalink)
Arizona Turbo Kings!
Feedback Score: 8 reviews
AZTURBO_SE - 1.816 60', 11.9 @ 119mph (1998 Sentra SE, White)
Ryan Nielsen
1997 200SX SE-R - Turbocharged Beast!
"While most are dreaming of success, winners wake-up and work hard to achieve it."
www.hpautoworks.com - ALL YOUR PERFORMANCE NEEDS!
480-829-0565
AZ_TURBOSE is offline
Old 02-23-2002, 11:33 AM   #7 (permalink)
Re: Quickest Turbo 1/4 Mile Times - The List
Originally posted by slowSER
[B]
Example:
2003 Lightning | 1982 Camaro Z28, ESP autocross car
slowSER is offline
Old 03-01-2002, 06:54 AM   #8 (permalink)
NismoB13SE-R - 2.17 60' , 13.18@108.21 mph (1991 SE-R, White), JICAEOU^SD
1991 SE-R with blue bird det (stolen sold shell)
1992 SE-R rear ended...total loss
1992 S13- KA power... right into the side of a metro bus.. i hate ice
1995 S14-...
1987 Pathfinder SE Redneck'd out
NismoB13SE-R is offline
Old 03-06-2002, 11:35 AM   #9 (permalink)
Fmax Stg II B13
PDXS2000 2.1 60', 12.31 @117.8mph (1991 SE-R, White) XCXMU^LSKR
The first X is a kit, and the second X is cams... in accordance with the codes
Old 03-15-2002, 11:19 PM   #10 (permalink)
11SEC CLUB
FMAX STG 2 CUSTOM EXHAUST & INTERCOLER PIPING
SYLVIA INTERCOOLER
1.826 60' 11.78@120.10MPH(1996 200SX BLACK)
XCEPVMOU^SKR
11.55@124.24 mph
FULL INTERIOR
367HP 340FT-LBS @18PSI
My Webpage
insaneser is offline
Old 04-08-2002, 02:06 AM   #11 (permalink)
GUPAMF 4 Life
13.3@104
Terrin
92 SE-R
92SE-R is offline
Old 04-13-2002, 02:39 PM   #12 (permalink)
70/30 Racing
Rockwood's Avatar
HotshtSR20 - 2.278 60', 13.973@101.70 (1998 SE-R, white) JICAEVU^SD
MotoIQ Project G20:
Rockwood is offline
Old 05-03-2002, 04:24 AM   #13 (permalink)
SE-R Turbo Slut
Feedback Score: 36 reviews
13.2@107mph 2.060ft 15inch slicks full interior including baby seat and bad alignment with t-28
Larry Low
http://s294.photobucket.com/albums/mm106/low612/
LAMO IMPORTS
k6 GSXR 750
08 Ducati 1098s Black
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline
Old 05-05-2002, 08:02 PM   #14 (permalink)
70/30 Racing
Rockwood's Avatar
HotshtSR20 - 1.921 60', 12.930@107.08 (1998 SE-R, white) JICAEVU^SD
Rockwood is offline
Old 05-06-2002, 03:23 AM   #15 (permalink)
SE-R?
13 sec club
Turbo b13 se-r 2.4360ft. 13.86@103mph
92 se-r, gray, JAEV
06 evo IX SE
turbo b13 se-r is offline
Old 05-24-2002, 12:16 AM   #16 (permalink)
turboser91 1.829 60' , 12.668@ 108.80 mph 91 se-r white
mods jaeu^skr
12.66@108.80 with a t25
turboser91 is offline
Old 05-29-2002, 07:29 AM   #17 (permalink)
Bone stock U12 DET
click [PULSSSAR] click
1995 Nissan Pulsar N14 SSS, sr20det and bitz, Perth, Western Australia
http://turbo.pulsar.org.au/webimages/barlogo.jpg
PULSSSAR is offline
Old 06-18-2002, 01:41 AM   #18 (permalink)
Boost Addict
any guesses on a 95 200 w/ bb det, sr20 DP, ACT S/S, JUN UL flywheel, stock I/C, 3in exhaust ES MM, and G-force Drag
ITR_KILLR is offline
Old 06-29-2002, 02:49 PM   #19 (permalink)
Skiddusmarkus 1.8 60',12.7@106mph(GTiR)
IAEMU^S
skiddusmarkus is offline
Old 07-30-2002, 08:13 PM   #20 (permalink)
http://www.dromadaire.com/nx2000
djisnx2000 is offline
Closed Thread
