Old 02-16-2006, 03:34 PM   #61 (permalink)
Joekuh
B14 Interior Designer
ok.....so we know WHY the b15/p11 tranny is an upgrade. MY question is when: when do you have so much horses that getting the upgraded tranny should be a good option?
Originally Posted by SmilyFace View Post
I know that MOMO hubs crush and save you. In case of an accident those long bolts in my hub are supposed to go right thorough my heart... ...so that I don't have to suffer, and die happy.
Joekuh is offline   Reply With Quote
Old 02-16-2006, 03:35 PM   #62 (permalink)
McCoy I am a moderator
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 72 (100%)
when you break your tranny, then that would be a good time to upgrade
Old 02-16-2006, 03:49 PM   #63 (permalink)
Joekuh
lmaooooooooooo thank u smart guy
Old 02-16-2006, 03:56 PM   #64 (permalink)
McCoy's Avatar
I'm felling nice today... I did a search for you and all.
http://www.sr20forum.com/showthread.php?t=95896
Ohh, and the answer is that there is no real answer to your question... just depends on how hard you are on the tranny, the clutch/PP you run, and so many other little details that it's hard to put into one sentance.
Old 02-16-2006, 04:40 PM   #65 (permalink)
Joekuh
i figured, but the only extremely stupid question would be the unasked one........and thanks 4 helping me in my search
Old 02-16-2006, 04:51 PM   #66 (permalink)
kesi24
WASHED UP
So true
Old 02-16-2006, 07:28 PM   #67 (permalink)
pddvl1
trans
But the p11 that from what year and I assume its g20 trans correct,? What years exactly do these come in ?thanks for any help
pddvl1 is offline   Reply With Quote
Old 02-16-2006, 07:53 PM   #68 (permalink)
CowboyDren
Simian Rex
'99 G20s have RS5F32' transmissions. You want a '00-02 G20 or G20t, which have RS5F70A or 'V transmissions, respectively.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 02-16-2006, 11:00 PM   #69 (permalink)
pddvl1
response to trans
thanks for the info I will locate one of these units thanks again
Old 03-27-2006, 08:02 PM   #70 (permalink)
RedDragun
The DET is in!
Trader Rating: 17 (100%)
So is the P11 tranny better suited to higher whp cars because of the longer gear ratios? I know you would go faster in the end but takeoff wouldn't be as strong though would it?
RedDragun is offline   Reply With Quote
Old 03-27-2006, 08:57 PM   #71 (permalink)
pddvl1
you got me check with jgy customs they told me they would build my b13
ser trans to hold up to my 400 hpbut thats is the max.
Old 03-28-2006, 03:48 PM   #72 (permalink)
jerryeads
Is an SE-R/VE a VE-R?
Has nothing to do with ratios. The gearbox case as well as internal supports are stronger, so no 3rd gear trashing or 5th gear popout. Assuming you can read and have the skill and motor dexterity to find the first post in this thread, you will find the answer to your question provided quite clearly.
'93 B13, etc.
do it over and over again?
Old 04-16-2006, 12:19 AM   #73 (permalink)
xueR
so these p11 b15 trans bolts right in??into b13.....that is...
xueR is offline   Reply With Quote
Old 04-16-2006, 02:49 AM   #74 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
With some modifications yes, but for the most part its just swapping parts from your old tranny.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 07-13-2006, 10:53 AM   #75 (permalink)
Sigfod
Sigfod's Avatar
I have blown one trans in my 2000 Sentra. Is there anyone who offers strengthining services for these trans?
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2006.5 2006.5 GTI DSG 2.0T FOR SALE
2008 BMW 328xi Touring
2008 BMW 328xi Coupe
Sigfod is offline   Reply With Quote
Old 07-13-2006, 11:36 AM   #76 (permalink)
nismo94tuner
Something in the works...
Trader Rating: 44 (100%)
^How did you manage to blow your tranny especially all motor? There are guys running 400+whp that don't blow them. One guy on this forum blew his finally after 30,000 miles and 500whp daily. What went wrong with yours?
-Bes
92 Sentra
----BNB----
Squaddd up
Old 07-13-2006, 11:42 AM   #77 (permalink)
Sigfod
Sigfod's Avatar
They never told me. I put it into gear and nothing happened. Made a god awfull noise though.
Old 07-14-2006, 12:35 AM   #78 (permalink)
nismo94tuner
That is unheard of. Maybe you had a tranny leak and had no gear oil in it? Not sure...
Old 07-14-2006, 09:36 AM   #79 (permalink)
Sigfod
Sigfod's Avatar
I never saw a leak I was under there not that long before. My guess is that my shortshifter is causing problems. The centering spring in the shifter is too tight now and pulls it to one side. I believe this is putting tension on the internals of the trans and causing premature wear? But WTF do I know?
Old 07-15-2006, 04:04 PM   #80 (permalink)
tunerguy
The Calibrator
For the Nissan Newby's WTF is a B15?
tunerguy is offline   Reply With Quote
