Old 07-15-2006, 04:45 PM   #81 (permalink)
CowboyDren
Simian Rex
B15 is the current generation of Sentra platform. Specifically, this thread refers to the B15s equipped with the QG engine ('00-present XE, GXE, 1.8S) and SR engine ('00-01 SE). The other B15s with QR engines ('02+ SE-R, SE-R Spec-V) use a totally different transmission family, which has limited applications in B13s ('91-94 "Classic" and NX2000) and B14s ('95-99 Sentra, 200SX), due to space constraints and lack of a factory-equipped, hydraulically-operated clutch in those platforms. The RS5F70A/V transmission was not available in any other car in the US except for the '00-02 P11 (Infiniti G20).
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 07-15-2006, 05:07 PM   #82 (permalink)
blackb13
Corporate Bullsh*t
^How did you manage to blow your tranny especially all motor? There are guys running 400+whp that don't blow them. One guy on this forum blew his finally after 30,000 miles and 500whp daily. What went wrong with yours?
Actually, he stripped the spline on the clutch disc. The tranny AFAIK is still perfectly functional.
92 SE-R, turbo
blackb13 is offline   Reply With Quote
Old 07-15-2006, 06:14 PM   #83 (permalink)
Sigfod
Sigfod's Avatar
A B15 is a 2000 - 2006 Nissan . The 2000-2001 Sentra SE had the 2.0L SR20DE motor w/ roller rockers and 1/2 the counter-weights on the crankshaft. It had 145 HP also.
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2006.5 2006.5 GTI DSG 2.0T FOR SALE
2008 BMW 328xi Touring
2008 BMW 328xi Coupe
Sigfod is offline   Reply With Quote
Old 07-16-2006, 09:19 AM   #84 (permalink)
tunerguy
The Calibrator
thanks for the info.
I am from the dark continent and we have'nt seen a Sentra since 99 or so.I think its a B14.
Busy building a DET motor with some very nice groceries hoping for 300+kw wheels plus a healthy shot of Nos.
We have allready fitted a LSD cable box I think its a P11.
How do they cope with that kind of power?
tunerguy is offline   Reply With Quote
Old 08-25-2006, 08:34 AM   #85 (permalink)
eXtremist
SR20DET
Does the B15 gearbox have a different part number to the B14 gearbox?
eXtremist is offline   Reply With Quote
Old 08-25-2006, 09:02 AM   #86 (permalink)
hpro123
SE-R GREEK
Yes it does but Ido not even remember the Part # for the B13 tranny!!!
Still, the MODEL # for B13/B14 was RS5F32V (with VLSD) or RS5F32A (open diff).
Likewise, the infamous B15/late P11 trannies are RS5F70V and RS5F70A.
hpro123 is online now   Reply With Quote
Old 08-25-2006, 08:36 PM   #87 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
they use a beefier gear set, I believe its the same as the maxima.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 08-25-2006, 09:06 PM   #88 (permalink)
CowboyDren
Simian Rex
That's a different B15 transmission. The '02+ SE-Rs (QR25 engine) use the same transmissions found in Altimas and Maximas. The topic of this conversation is the '00-01 Sentra and '00-02 G20 (SR20 or QG18 engine) transmission, which are pretty much unique in the Nissan family.
Old 08-25-2006, 09:33 PM   #89 (permalink)
SENTRASER
SENTRASER's Avatar
Ah, thanks for the correction, where you been bud?
Old 08-26-2006, 12:07 AM   #90 (permalink)
SR20Turbofreak
done
I have not destroyed a B15/P11 gearset. I have however broken a synchro Hub slider ring, and I have stripped the clutch splines on 3 clutch disks with my last motor. I have not boosted all that power on the track( road racing) but on the drag strip without slicks seems to hold ok.
Old 08-26-2006, 12:21 AM   #91 (permalink)
SENTRASER
SENTRASER's Avatar
What kind of clutch have you been using? Considered having the clutch disk cryotreated to hold up?
Old 08-26-2006, 10:04 AM   #92 (permalink)
eXtremist
SR20DET
Can the gears on the RS5F70A input shaft be removed & replaced because I know that the gears on the RS5F32A can not be removed.
Old 08-26-2006, 10:31 AM   #93 (permalink)
Sigfod
Sigfod's Avatar
How much power were you putting down?
Old 09-11-2006, 01:31 PM   #94 (permalink)
8lack5unsr20
ok so i have a 1991 se-r so the b15 tranny is an exact wap into my kind of car??????????? do i have to do any mods?????
8lack5unsr20 is offline   Reply With Quote
Old 09-11-2006, 01:33 PM   #95 (permalink)
Sigfod
Sigfod's Avatar
All I know is in order to get it to fit a GTi-R motor you have to Mod the axles or the brackets to make it all work.
Old 09-11-2006, 01:37 PM   #96 (permalink)
8lack5unsr20
what mods do i have to do to get the tranny to fit into my 1991 se-r sentra???? i need some help first tranny swap ....so can u help me out thanks a lot
Old 09-11-2006, 02:01 PM   #97 (permalink)
McCoy I am a moderator
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 72 (100%)
Search... the details of how to do this have been posted a few times
furthermore, this thread is in the technical library, a place to supply you with information... not for you to come in here asking questions that I KNOW that you have not searched on. If you still have questions after searching, start a new thread in the appropriate section...
*Edit* - Damn, in this same section is a large thread on how to install a B15 tranny in a B13, how hard did you look again
http://www.sr20forum.com/showthread.php?t=97257
Old 10-01-2006, 01:37 PM   #98 (permalink)
8lack5unsr20
so u dont have to mod the axles just pulg and play after the grinding off just bolt on an drive?????
Old 04-05-2007, 09:22 AM   #99 (permalink)
unijabnx2000
where do i put it?
any body know of a good shop that will do the conversion from the b13 to the b15 tranny for a reasonable price?
Old 04-06-2007, 08:23 AM   #100 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
