Old 02-17-2005, 06:11 AM   #21 (permalink)
CoZZm0
Originally Posted by cubanprince1
I have a b15 tranny and am having a noise that sounds like a rod knocking come out of it but when i press the clutch in it just goes away. Let go of the clutch and it comes back. I took it to a professional tranny shop and the dude said it sounds like the input shaft bearing to him.......From these pics, i just dont see how an input shaft bearing will be making that clacking sound. Im no tranny expert but wow...any suggestions/opinions?
if you put your foot lightly on the clutch, does the noise go away instatly? if so, then its probably the release bearing/thrust bearing for the clutch. I had the same issue, then i replace my clutch, 20,000km later i had the noise back again and then it got so bad it sounded like a belt slipping every time i put my foot on the clutch and like the motor was falling out of the engine bay onto the ground.. lol. Release bearing was rooted again. I'd say that's more likley your problem than the input shaft bearing.
CoZZm0 is offline   Reply With Quote
Old 05-15-2005, 01:38 PM   #22 (permalink)
NX$paniard
easy 400WHP
Trader Rating: 26 (100%)
so the Phantom Grip # 906 would work then correct? (Thats the one fro the B13 LSD)
~jRod
Old 06-20-2005, 12:09 AM   #23 (permalink)
NX$paniard
easy 400WHP
To answer my own question, Yes the 906 Phantom Grip Works in a P11 Trans. Also,
Thansk a bunch for this thread!! We could not get the P11 Trans apart without looking on here. Its worse than a Honda tranny from what I understand
Old 06-20-2005, 10:03 AM   #24 (permalink)
coalitionSE-L
Grandma's gonna get ya!
coalitionSE-L's Avatar
No problem. It's not as bad as it may seem once you start ripping into it. Good luck!
1999 SE-L SR20DET-- Sold!
Old 07-22-2006, 08:08 AM   #25 (permalink)
src
Hello guys! How much breakaway torgue have this type of LSD?
src is offline   Reply With Quote
Old 09-29-2006, 04:17 PM   #26 (permalink)
zerosin
One bruise at a time
zerosin's Avatar
Trader Rating: -1 (0%)
Thanks for the write up, it made the disassembly go much quicker.
I needed a slide hammer to get the reverse idler shaft out though what a PITA. Darn Michigan winters eatin' away at my car. I had some slick snap ring pliers, you adjusted them by turning the handle so they locked into posistion. I set them to the lock ring opening and tapped them with a hammer and bingo! 10 seconds a ring for removal.
I did have to play around with the shifting forks to get the shaft to come out. 2 and 3 needed to be moved up or down a bit to get 1 out because of the check ball/shaft on the side of the shaft facing the differential. Same with 2, 3 needed to be moved up a bit before I could get the shaft out for 2. After that it was a breeze. Definately not a project to be scared of.
I've added Thermoblok spacers to my intake mani, and I'd have to say that removing the tranny and opening it was about the same if not easier. I haven't put it back on yet though so we'll see.
Here's why the tranny needed to be dropped:
http://www.sr20forum.com/showthread.php?t=171741
Installing a VE into an sr20 B15
http://www.sr20forum.com/sr20ve-sr16...e-project.html
zerosin is offline   Reply With Quote
Old 09-29-2006, 06:50 PM   #27 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
http://www.matcotools.com/Catalog/to...&page=3&#32190
Are those the snap ring plyers you're refering to? I'm always looking for an exscuse to buy a tool
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 09-29-2006, 06:57 PM   #28 (permalink)
zerosin
zerosin's Avatar
These kind (which rock by the way) with tips bent less extreme that this pic, more like 10 degrees or so.
Old 04-15-2007, 07:09 PM   #29 (permalink)
benjamz
how similar is this to the p10 tranny, i need to rebuild mine.. have factory lsd.. t model also def gonna install the phantom grip now.. awsome awsome awsome write up!!!!!!!!!!!!!!!!!!!!!!!
benjamz is offline   Reply With Quote
Old 04-22-2007, 10:03 AM   #30 (permalink)
01turbosentra
hey i had the same prob and yesterday it finaly blew up yeah mine was makin a thumpin sound with the clutch locked and depressed it would go away and well yesterday i was messin with sum people on the road and i lost 2nd 3rd and now the case is cracked looks like the gear pieces came through the tranny noting the huge gaping hole in the bottom of it haha
01turbosentra is offline   Reply With Quote
Old 04-22-2007, 03:30 PM   #31 (permalink)
zerosin
zerosin's Avatar
Been there, caught it time though and fixed it.
Old 04-22-2007, 11:04 PM   #32 (permalink)
capecodbuysell
anybody tried this with the nismo diff?
capecodbuysell is offline   Reply With Quote
Old 05-03-2007, 10:59 PM   #33 (permalink)
01turbosentra
ok ive forgotten on how the ball bearings go in the shifter rods can anyone help with that one i have a long bearing a medium one and several other rounds ball bearings
Old 05-04-2007, 10:08 PM   #34 (permalink)
zerosin
zerosin's Avatar
Do you have the FSM?
Old 06-25-2007, 04:41 PM   #35 (permalink)
Charvy
where I can buy LSD Phantom Grip or JGY custom for Nissan Sunny GTI N14(SR20DE)?? Thanks
Charvy is offline   Reply With Quote
Old 11-13-2007, 09:39 PM   #36 (permalink)
NxDET
lsd question
HI, I got a b13 tranny and wanan buy a no lsd b15 tranny. I wanna put my b13 lsd on the b15.
Do you get info for the difference with stock lsd b13 and differrence with aftermarket such as phantom one ...
IS that big difference or really similar? for performance, handling
got place or website to see specs/buy one lsd?
From now, I could no more access Nismo parts store from nissan usa website or nissan.ca, I'm searching for the new website. dawm
NxDET is offline   Reply With Quote
