Disassembly of B15/P11 tranny/install of friction type LSD - Page 3 - SR20 Forum
Old 03-30-2010, 10:56 AM   #41 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
Originally Posted by NX View Post
theyll fit if you change the ring gear iirc??? I wa spretty sure the LSD itself was the same, just the gear was different.
thats what i read when i did my research
...Currently down due to a clutch disc spring failure....
Old 05-01-2011, 11:29 AM   #42 (permalink)
Don't deny Jesus Christ
Feedback Score: 12 reviews
But how can u fit the b13 lsd into the b15 non lsd case? Isn't the non lsd case lacking the bulge that the lsd ones have? (Driverside axle slot in the tranny)
My HUGE FOR SALE THREAD with parts screaming, "Buy me!" Hahaha
http://www.sr20forum.com/cali/272387...isc-parts.html
One day for God is a thousand years for us.
Mr. Sleeper is offline   Reply With Quote
Old 05-01-2011, 03:39 PM   #43 (permalink)
Stop Lying Or youll lose
Looks reliable, untill you stress that thing out with highoutput horsepower then you see how that lsd kit can handle
Sr20&K20 is offline   Reply With Quote
Old 05-15-2011, 08:44 PM   #44 (permalink)
I cant seem to get the second shifter rod out ... ideas??
Old 05-15-2011, 09:04 PM   #45 (permalink)
Make sure the third rod is not engaged into any gear and u might have to move it up and down, causing the check balls to free-up some space so u can pull it right out.
Old 05-15-2011, 09:06 PM   #46 (permalink)
I'll go try that thanks
Old 05-15-2011, 10:02 PM   #47 (permalink)
Which is correct?
Old 05-28-2011, 01:59 PM   #48 (permalink)
Thanks for the write up. It helped me change my bellhousing
