Gear Ratios for B13\14 & P10\P11 - Page 2 - SR20 Forum
Old 06-19-2008, 09:05 PM   #21 (permalink)
b13 got 14inch tires oem...
Visit http://docauto.blue-soft.net/
or
http://docauto.cjb.net
dedicated site for cars forums and videos
NxDET is offline   Reply With Quote
Old 07-19-2008, 06:21 PM   #22 (permalink)
'93 drifting Egg
I have a 91 SE-R with B13 trans, and B14 SE-L wheels with 195/50R15 tires. At 65mph in 5th I am at around 3200rpm, and at 80mph in 5th I am around 4000rpm. 7500rpm in 3rd is about 89-91mph.
1986 300ZX Turbo with 90k miles
1994.5 B13 Sentra Limited Edition, mint daily
NissanEgg is offline   Reply With Quote
Old 12-03-2008, 11:26 PM   #23 (permalink)
how about the all wheel drive trans with transt=fer the gears fit a usd trannny or can they be interchange
mercado se-r is offline   Reply With Quote
Old 02-18-2009, 05:08 PM   #24 (permalink)
Pretty much nothing is interchangeable between 4wd lsd and FWD non-lsd trannys.
I opened both tonight and gears/final drive count different and both parts of the housing are also different.
Sure you can swap certain parts, but you cant just switch out gearstacks or diffs.
Freek is offline   Reply With Quote
Old 10-04-2009, 03:30 PM   #25 (permalink)
Done.
Feedback Score: 27 reviews
Would a moderator please contact me regarding this thread? The spreadsheets given do not contain the correct formulas, so the MPH calculations are off.
I re-created a spreadsheet/workbook given the correct diameters and circumferences, so that the MPH reports are consistent with OEM wheel/tire combos. This will give an accurate starting point for those wondering what's what. In addition, I provided a formula in my spreadsheet that will allow the individual to calculate their own tire diameter, which they can plug in and immediately see the change in MPH across the entire spreadsheet.
Thanks!
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff está en línea   Reply With Quote
